mamba max
lind5
mamba max - 08.27.2008, 05:02 PM
hi i have just got a mamba max im going to run it with my f/7xl can i run it on 2 x 8.4 v nimh batterys or do i have to stick to my 7.4 v packs
i cant run lipos at the moment but should be getting some zippy r lipos soon
or ould this be to much for my little mamba max
08.27.2008, 05:16 PM
You will need a BEC (cc bec or similar), I would add an extra cap (novak hv 2700uf) and potentially a fan (25mm 5v)...
TruckBasher
TruckBasher's Avatar
08.27.2008, 08:20 PM
BEC and FAN is a must....I run mine without extra caps with 6S A123..2 x 7 cell NiMH should be fine....if you are still hesitant get the caps
E-Slayer direct drive to diff
lind5
08.28.2008, 08:36 AM
ok mate i have fans and i have the ubec that rcmike sell on here so ill give it a go not sure about these caps though do you wire them between the
+ and - that go to my battery
i havent realy had these or used them before
TruckBasher
08.28.2008, 08:54 AM
As I know Caps...there is a marker for negative. Usually a line white or gold or whatever with negative sign...but using it on ESC I am not an expert as I havent connected one yet...2 of my MM running 5S and 6S run fine without caps...
hope this helps
08.28.2008, 09:01 AM
Lind5 - the easiest is to go with the novak HV 2700uf cap - it comes ready to install across the power lines and the leads are coloured. It will help the esc absorb some of the voltage ripple.
lind5
08.28.2008, 05:02 PM
nice thanks mate sounds easy enough
i dont have a good track record with esc's cooked three now starting to get very expensive
TruckBasher
08.28.2008, 07:57 PM
hmmmm not sure why 3 ESC got cooked but you might want to look at your gearing and setup...btw where are you putting the 7XL MM combo? I hope its not a heavy truck of truggy...
lind5
08.29.2008, 02:53 PM
well i guess it is quite heavy its my converted lst2
you think this could be a problem for me
i do have a neu 1515/1.5d 2700kv motor woould this be a better choice
or not
