MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.08.2008, 11:20 PM
Why did the ccbec smoke?
entjoles
09.08.2008, 11:31 PM
well i have 2 things in mind
the first is i wanted to change the output v on the ccbec and it didnt work , i dont know if i needed a diff program from cc or ? although it was soldered to the esc. the batterys were not hooked up.........
the second thing i was thinking was that i plugged it in and left the esc. switch off , then i went outside , i live in an apartment so the ccbec was on because the batterys were hooked up and it took about 2 min. for me to put the body on and go outside to run.....??
dont know , i just hope that the servo and rx are ok , they seemed to work good the second time i tryed to run until the esc. quit??
ptt81
09.09.2008, 02:30 AM
thats weird, if you managed to fry the ccbec, there is a chance you have fried the MMM bec in the exact same way, thats quite a coincidence, something must be wrong with your setup, like a short in wiring somewhere that you are not aware of may be. I've been running my V2 MMM flawlessly thru 6 packs so far with SportBec and fan wired to RX directly
entjoles
09.10.2008, 12:06 AM
well idecided to try one more thing before i send it back and it fired right up!!!!!!!!!!
it links with usb so i left the red wire in and used a rx pack and it works
i hope i will get some running with it as is for awhile , and wait to send it back
George16
Supermaxx
George16's Avatar
09.10.2008, 12:09 AM
Good to hear it's working!!!!
Did you plug the rx pack directly into the battery port of your rx? What about the fan?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
entjoles
09.10.2008, 12:11 AM
yes , i just hope it holds for awhile , i want to run my truck so bad
she will get beat but good asap
