Go Back   RC-Monster Forums > Support Forums > Team Tekin
cheesecake
09.16.2008, 01:23 AM
how would a teken r1 pro do in a truggy on 5s with a neu 1515 2.5d im thinking of getting one for the and i was going to find a way to mount a fan on it
ffactory666
09.16.2008, 03:33 AM
I can't comment fully , but i have run my R1 Pro with 35v cap and external bec in my X2 truggy with no problems , set up similar to yours 5s , Medusa 1600kv motor. However it was winter over here and i only ran it a couple of times for around 10mins each time and heat was no issue .
Didn't want to push it fully as i bought the R1 to run in my buggy which is on it's way ( Hot Bodies D8) but while waiting for my MMM v2 to arrive i thought i would give it a little run in the truggy .
If you could get a fan on it i don't think you will have any problems . You could use a piece of thin alloy mount the R1 Pro to it then bend it up to face the solder tabs , then attach a fan to the alloy which is facing the solder tabs ( nearly did this in the truggy while waiting forever for the MMM ) .
cheesecake
09.16.2008, 04:11 AM
im going to have to order one and see what i can do
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.19.2008, 04:32 AM
Is the power cap in Mikes Store good for the R1 Pro running 5S 1512 2.5D?
http://www.rc-monster.com/proddetail...=35vcap&cat=21
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Kajman
Kajman's Avatar
09.19.2008, 04:37 AM
any updates to relase time of rx8?
DRIFT_BUGGY
09.19.2008, 05:19 AM
How is everyone mounting the fans to the R1 Pro?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
jhautz
jhautz's Avatar
09.19.2008, 11:39 AM
Id run 2 of those I am running a single 2200mfd. I think Mike is using a single 1800mfd.
to make it...
or break it...
Silent...But Deadly
jhautz
jhautz's Avatar
09.19.2008, 11:41 AM
Not easy to do. Just find a way to mount it so it blows on the solder posts. It probably wont be attached to the esc itself. More likely attached to something else and pointedat the esc. Not much room to work with mounting on the little guy.
to make it...
or break it...
Silent...But Deadly
DRIFT_BUGGY
09.19.2008, 03:19 PM
Would one of these work?
http://www.jaycar.com.au/productView...Max=&SUBCATID=
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
ffactory666
09.19.2008, 05:10 PM
No good , you need a 35v and at least 1800uf .
I posted a link which i can't find for you
Get the 35v cap from Jaycar , they only come in 1000uf so buy two and run them in parallel for 2000uf , make sure it's the low esr radial cap when you ask
Mounting a fan , just bend a piece of thin alloy 90o .Place the esc on it and then face the bent bit towards the solder posts , mount the fan to this and you will have it blowing at the solder posts .
You can make the bottom part of the alloy a bit wider and drill some mounting hole in it while having the esc attached to the alloy some how , maybe double sided tape and a zip tie for security .
Kajman
Kajman's Avatar
09.22.2008, 03:10 AM
How do you compare MMM to R1Pro? Drive feelings? I can see you have both of them.
DRIFT_BUGGY
09.22.2008, 03:24 AM
Alot of people say the R1 Pro has smoother throttle
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
ffactory666
09.22.2008, 06:07 AM
R1 is smoother and has much better brakes going by guys who have used both .
jhautz
jhautz's Avatar
09.22.2008, 08:41 AM
Yep.
The best way I can describe it is the R1Pro just feels more precise.
to make it...
or break it...
Silent...But Deadly
brushlessboy16
brushlessboy16's Avatar
09.23.2008, 05:42 PM
Yep.
wow that says alot, i just ran my MMM, and it is verysmooth at low rpm
