09.24.2008, 01:12 PM
Nice, but you will *most likely* have to also buy their $150 lathe stand.
09.24.2008, 01:36 PM
I have some really sturdy metal tables, that I can use as a stand.
09.24.2008, 01:41 PM
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
09.24.2008, 02:46 PM
Linc, im also working on a center diff design as well.......i should have all the parts by this weekend hopefully, and as for some of the lathe work, I'm able to do it at work, at my lunch time......
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
SnoopMaxx
SnoopMaxx's Avatar
09.24.2008, 03:21 PM
Looks a little like the one I have at work
I also gave the machinist some diagrams and material to make the adapters to put lst diff cases in a maxx. So I will have a new thread on that soon. Those are much simpler to make, and should provide a good alternative to the other 1/8 scale maxx diff conversions...
That sounds great
Morten SnoopMaxx
Never to old to play
c",)
09.24.2008, 03:23 PM
Shall be interesting to see what you come up with. I have my patent number for mine already, so hopefully you are not infringing on my design...
sjcrss
sjcrss's Avatar
09.24.2008, 04:25 PM
nope not at all...this is what im doing......
so here is what i have coming and planning
purchased the following
traxxas cd
ofna hyper 6 spyder diff
acer 8X12 bearings...( these will fit onto end of diff cup and still fit into stock tranny bearing hole, which is 6X12 bearings)
here is the plan....
take apart the traxxas diff, measure it's cup to the hyper diff, use the traxxas outputshafts, with ofna spyders( hopefully they mesh good ) then use the gear off the Traxxas cd... and bolt it to the ofna ring gear, after the teeth are machined off, then drill & tap 4 holes to hold the traxxas lower gear to the modded ring gear... on the front side of the output shaft...I will use a std. 6X12 bearing..... so the back of the diff will be supported in the bearing hole, and the front by the shaft.....that is the intent anyways.......so I hope you don't see this as infringment.....but after seeing yours, i figured there has to be an easier way.....so that anyone can possibly make one with the right parts and some work at the bench at home.....but I'll post pics ect.... as i try to get it all together....
Bl E-REVO
Quark 125b
((2s2p)(4s)
09.24.2008, 04:49 PM
traxxas cd
I was just joking. It will be interesting to see how you do with drilling the ofna gear, as it is hardened. Please post some pics when you get some progress.
sjcrss
sjcrss's Avatar
09.24.2008, 04:53 PM
np...lol, im actually gonna have one of our seasoned machinists at work drill & tap them...he is also runs rc's as well, so he knows about the gear too....i hope the simplier design will work.....not trying to take anything from you.....just seeing if my idea will work......however if it does...I wont produce them (unless people are asking for the modded ring gear....), but more than likely will post info on how to do it yourself.....
Bl E-REVO
Quark 125b
((2s2p)(4s)
09.24.2008, 05:17 PM
My setup is quite involved, not sure if it is worth selling it as it will be expensive. I really need to test it out and see if it will last. I have another idea of how to make it a bit better and simpler. Good luck with your idea, hope it works...
Have you found out if traxxas will sell the output gear seperately like they do with the nitro revo?
sjcrss
sjcrss's Avatar
09.24.2008, 05:42 PM
nope not yet, however, if they do, and the output shafts work....then all someone would need to do is purchase the output shafts, the gear, and a complete ofna diff cup...and be all set....
Bl E-REVO
Quark 125b
((2s2p)(4s)
sjcrss
sjcrss's Avatar
09.24.2008, 06:04 PM
double post...ooops
Bl E-REVO
Quark 125b
((2s2p)(4s)
torqeroll
09.24.2008, 08:29 PM
nice job, i love to make stuff!!!!!!!!! i picked up my lathe for 500.00 bucks used . its an old military lathe but works great , i think investing in a lathe is a good investment. KEEP UP THE GOOD WORK!!! HERES SOMETHING I BUILT WITH MINE , IN MY GARAGE
09.24.2008, 08:53 PM
Originally Posted by torqeroll View Post
nice job, i love to make stuff!!!!!!!!! i picked up my lathe for 500.00 bucks used . its an old military lathe but works great , i think investing in a lathe is a good investment. KEEP UP THE GOOD WORK!!! HERES SOMETHING I BUIL WITH MINE , IN MY GARAGE
That is nifty looking, what is it?
torqeroll
09.24.2008, 09:05 PM
thanks, its a 6 to 1 gear box i made for a giant size neu for a 102 inch giant aerobatic plane, swings a 31 x 18 custom prop
ID:	5497   Click image for larger version
Name:	thumb-yak with bam (1).jpg
