I'd say the Wabash are negative offset, and the top pic you posted are standard... anyway, I'm looking for positive offset.
I tried the CHeyenne 40s and they rub, need more offset. As far as I can tell, PL has no offset 40s with 23mm hex. They offer the 1/2" offset for standard tires, but not 40s.
Any ideas guys?
Hm, thanks. It's a TwinForce. I think the ones you found require this set-screw in the axle... Savage stuff would work. Or I could buy these, make a groove in them on a lathe and put an O-Ring over the pins. Would be just a band-aid though, and I need someting proper. It's a customers truck.
Got another suggestion?
Thank you so far! Appreciated!
