whitrzac
Can't catch this...
whitrzac's Avatar
10.09.2008, 11:34 PM
I already bought a new one, what is the medusa? were can I find some info on it? this is the first time I'v hered of that motor
Unsullied_Spy
Unsullied_Spy's Avatar
10.09.2008, 11:38 PM
http://www.rc-monster.com/proddetail...usa3650&cat=20
That's it. It'll put out a great deal more power than a 4600 but if you already bought a new motor I wouldn't worry about it.
whitrzac
Can't catch this...
whitrzac's Avatar
10.09.2008, 11:56 PM
:surpr ised:I got a mm esc and motor for that price
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.09.2008, 11:59 PM
Maybe you did, but that Medusa will outlast and outperform the CC cm-36 series motors. Not ripping on CC, they're a great company with great products. The Medusa is far more efficient and runs ALOT cooler.
Unsullied_Spy
You got a good deal. I paid ~$210 for my MM 5700 combo from Tower. It ended up being less than that because of the discount code but I bought a ton of other stuff.
whitrzac
Can't catch this...
whitrzac's Avatar
10.10.2008, 08:55 AM
how will it out last if it has "cooling holes" that dirt can get in?
I got my MM so cheap because I got a free "fried" one that I sent in.
brushlessboy16
brushlessboy16's Avatar
10.10.2008, 09:06 AM
i believe you can use the RCM neu endbell covers with a little modding ( dont qoute me).
Medusa will rip a cm36..
i wonder if castle will replace the cm36 with a castle neu 1509?
JaySki
JaySki's Avatar
10.10.2008, 10:07 AM
It's funny you are dropping your Jaw at a $115 Medusa.... Many of us in here run, or have, NEU 1515s at $250 a crack.
Not to get into a peein contest, but I have a Tekno NEU 1515 1.5D, just got my Tekno NEU 1515 1Y, and I have a Medusa 36-60-2000 V2. I can pretty much bank on that I won't have motor problems. It's one of those things that in many cases, you get what you pay for.
Hobbies are never cheap and if you are going to play in BL which raises the bar for "ease of use" you gotta have extras of dang near everything if you want to run, break, fix, and run. otherwise it is Break, order, wait....... fix, run.. maybe a week later.
George16
Supermaxx
George16's Avatar
10.10.2008, 10:08 AM
So you sent in a fried one you got for free from somebody and CC replaced it with a new one and now you're complaining that you have to pay for the broken motor?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
RBMike
RBMike's Avatar
10.10.2008, 11:26 AM
I have been useing a very hi tech solution to keep the dirt out of my Medusa motor all summer. I works very well & keeps the inside of the motor very clean. It's called scotch tape over the holes.
Unsullied_Spy
10.10.2008, 12:41 PM
Can't the dirt still work it's way in there? I'm using an RC-M heatsink clamp (probably use some aluminum foil between the motor and transmission) and a trimmed washer on mine. I E-Mailed Medusa and they suggested covering the holes when using it offroad.
You definitely get what you paid for, Neus are certainly worth the money. I haven't gotten my Medusa running (MM had some issues with it we couldn't work out over E-Mails so I sent it back to CC) but I have looked it over thoroughly and the initial quality is impressive.
whitrzac
Can't catch this...
whitrzac's Avatar
10.10.2008, 01:04 PM
I paid to have them replace the MM, but the motor was NIB from the LHS!!!!!
and dam right I'm complaining about the motor, it has a manufacuring defect and should be replaced
RBMike
RBMike's Avatar
10.10.2008, 01:05 PM
I also have a neu with the RCM covers on it & it actually gets more dirt in it than the Medusa with the wide tape over the ends. I peel it off once in a while & blow it out with air & less comes out than out of the Neu. The Medusa is holding up well & has many hours on it. I think neu's are the best but for the money I have no complaints about the Medusa & it is lighter than the Nue. Where you at in Montana?
brushlessboy16
step up to a medusa 50, or a 1509
whitrzac
Can't catch this...
whitrzac's Avatar
10.10.2008, 01:08 PM
ok, ok I get it, there awsome motors, but I just don't need something with that amount of power, yet.....
