rchippie
rchippie's Avatar
07.22.2008, 04:19 PM
Originally Posted by Serum View Post
RENE that sure is a nice buggy . From what i remember the mbx5 mount does not fit the mbx4 . But im not 100% sure . Also the kyosho plastic spur will not fit the mugen. You have two choices, either use the stock steel spur & some hardened pinions from mike, or have mike make you a adapter so you can mount the kyosho spur on the mugen .
Rene do you still have that car ?.
REAL MEN RUN BRUSHLESS
brushlessboy16
brushlessboy16's Avatar
07.22.2008, 04:34 PM
sweet ride
07.22.2008, 04:45 PM
Are you referring to mine, or Rene's?
brushlessboy16
07.22.2008, 04:52 PM
umm....yes!
I was asking BLboy, anyway, does Mike make any mounts that'll fit?
rchippie
rchippie's Avatar
07.22.2008, 04:59 PM
You will have to ask him . He may know if the mbx 5 mount will work .
07.22.2008, 05:09 PM
I think Mike already punted on this and said - He thought it would and said buy it and if it doesn't work return for refund...
07.23.2008, 11:33 AM
I'll do that as soon as some money rolls in... Taking MUCH too long. (him)(me)
08.08.2008, 06:46 PM
Ok guys, did a bit of work today. Got the front shocks mounted, as well as the servo and receiver. Take a look:
(Sorry about the next picture, it's terrible. I was lazy and didn't bother focusing.)
08.15.2008, 07:40 PM
Ordered all the parts needed to finish!
08.20.2008, 04:58 PM
Got my pinion, hopefully the conversion parts and MM come soon.
SilveradoHD
10.10.2008, 12:57 PM
I am about to order the parts right now to convert my MBX4-XR. I will be running a Medusa 2000kv with a MMM ESC and a Airtronics 358 servo. I will be using the cheap zippy packs. My question is, should I got for two 3s, or two 2s, or just go for one 4s,5s, or 6s? This car will not be raced other than drag racing so weight distrubution is really no concern unless it will greatly affect handling with one big pack. Would a 16t be sufficient on a 4s without overheating? What about if I step up to a 5s, or 6s.
10.10.2008, 09:18 PM
I'd go with a 4s and gear for ~40mph. Try Brian's calculator if you havem't already.
www.scriptasylum.com/rc_speed
SilveradoHD
10.11.2008, 12:40 AM
I already had the 5s ordered, should I cancel and go with a 4s instead, or would the 5s be dandy with the 2000kv medusa on a 13t or 16t pinion?
10.11.2008, 09:38 AM
Personally, I'd get a 1600kv medusa w/ 5s than a 2000kv medusa w/ 4s.
