Largest possible motor for CNC stampede/rustler transmission case?
andy85
Largest possible motor for CNC stampede/rustler transmission case? - 10.23.2008, 08:45 AM
i'm thinking about getting this case for my pede
http://www.rc-monster.com/proddetail...ny20000&cat=29
Does anyone know whats the largest possible motor that'll fit? i'm thinking of neu's 1515s range
david lamontagn
10.23.2008, 09:54 AM
I have this case on my salsh and run a Neu 1509 2.5d/s.
So if you use jato MOD0.8 pitch gear you,ll don,t have trouble to run a 1515 in it, BUT, you have to use the smooth can Neu, not the finned one.
And listen to me, you don,t have to put a 1515 in that, my 1509 push my slash like a rocket on 3s, not able to keep the front wheel on the ground
stampedeproject
stampedeproject's Avatar
10.23.2008, 10:45 AM
The un-finned smooth 1509 is the largest motor you are going to be able to run in a Stampede/Rustler/Bandit/Slash. Anything longer and you are going to have a real problem with the wires exiting the can hitting the tires. Even at that your gear ratio is VERY limited. I would look into a Medusa 70mm length as thier wires exit form the size vs. the end.
10.23.2008, 10:50 AM
A finned can neu will fit the flm tranny case, bit you will have limited adjustment. I ran a plett maxx which is similar in diamter to a finned neu. I used a 58t jato spur and a 15t pinion and it was fine. You will not need a 1515 motor in anything 2wd. I am sure that a 1509 will be plenty.
david lamontagn
10.23.2008, 10:52 AM
No proble to run longer than 50mm can, you just have to bend the wire, no trouble, but do it with caution.
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
10.23.2008, 12:23 PM
i've run the 1515 1 Y smooth can in my rustler with 6S...if you run the extended rear a- arms w/or in addition to integy 17mm adapters, there isn't even a wire clearance issue.
i however, don't really recommend a 1515 for the rustler....it's like putting a jet engine in a honda s2000.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
david lamontagn
10.23.2008, 01:23 PM
Ouch!!!!!!!! you're crazy man The stock slidder drive shaft should take a beat
DwightSchrute
10.23.2008, 01:40 PM
it didn't stay in the rustler for long ...although i used flm cvds.
the stock drive shafts got ripped on first throttle contact with the neu, and was really the only weak part in the drivetrain.
andy85
10.23.2008, 04:48 PM
thanks for all your input guys...
i'm a super speed freak so just as long as this rocket fits.... im happy =]
i have a 1515 2.5d sitting on the bench so may as well upgrade my pede to something with ALOT more bite!! heheh
10.24.2008, 10:37 PM
IMO, convert the pede to a rustler. Untold things will happen if you don't!
andy85
10.26.2008, 04:48 AM
nah i like the way a RWD TRUCK handles =] its a different experience
