DRIFT_BUGGY
DRIFT_BUGGY's Avatar
10.26.2008, 06:17 PM
Nice job with the wires on the MMM
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
George16
Supermaxx
George16's Avatar
10.26.2008, 07:42 PM
Have any of you installed a capacitor on the V3's?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Pdelcast
Pdelcast's Avatar
10.26.2008, 08:15 PM
Originally Posted by e-mike View Post
well if the thing continue to going good like that for the mmmv3 a lot of parts will be broken soon
Tell me about it. I think we went through like $8K worth of parts and cars wringing out the V3. (Including completely destroying 2 customer cars... and replacing the whole setup...)
Patrick del Castillo
President, Principle Engineer
10.26.2008, 08:25 PM
Do you need a better driver (ouch) or maybe a larger area to play/test?
Pdelcast
Pdelcast's Avatar
10.26.2008, 08:29 PM
I think we need less power -- our test motor for high power testing was a Neu 1521/1D -- on 6S. NEVER TRY THAT AT HOME. I'M SERIOUS.
We broke so many transmission and gearing parts -- seems every run we would get 2-3 passes and then something in the drive train would fail.
brushlessboy16
brushlessboy16's Avatar
10.26.2008, 08:49 PM
why dont you just build a go-kart, put 2 MMM and 2 2215 on 6s4p lipo
George16
Supermaxx
George16's Avatar
10.26.2008, 08:54 PM
Any videos? It would be really nice to see a 1521 on 6S .
By the way, any thoughts on installing a pair of capacitors on the V3?
Revo with OS .18TZ
macr0w
macr0w's Avatar
10.26.2008, 09:41 PM
I ran my MMMv3 in my new MBX-6 this past Sunday with a 1512/2.D/F and a 5000mah 25c Polyquest.
It ran great for three 6 minute qualifiers and a 20 minute main.
That's the most I've gotten out of an MMM since it came out. And I've been through 6 of them.
This may be the one fellas.
It felt smooth and it stayed together. That's all I can ask of it.
e-mike
e-mike's Avatar
10.26.2008, 09:58 PM
nicenow its seems that the v3 old on for the first 40minutes un runtime...let see at long term use
D8t on juice!!
bustitup
so am i right that we should just use the internal bec and dont do any mods to the v3?
e-mike
e-mike's Avatar
10.26.2008, 10:02 PM
now for the v3 the bec problem seem to be fixed....and no mod neededjust open the case to look if the fan wire isn't pinched...
D8t on juice!!
Unsullied_Spy
Unsullied_Spy's Avatar
10.26.2008, 10:10 PM
Check it out.
DRIFT_BUGGY
10.26.2008, 10:12 PM
I know have 5+ hours on my V1 since updating to 1.20 firmware and removing the EXT BEC and is still going as strong as ever and doesn't look like stopping
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
10.26.2008, 10:18 PM
Ahh, I see. Figured that crashes were causing the damage. A 2900kv motor on 6s sounds like fun. What vehicles were you using? I plan to use a 1521 1y on 6s in an erevo.... I doubt I will be as harsh as you guys due to the fact I am not trying to test the motor limits! But I am sure that you can tell me if the erevo will hold up?
Thanks for fixing the MMM Patrick, best esc out there.
david lamontagn
10.26.2008, 10:28 PM
NO it'lll not hold up.....never
