Parallel 5s lipos for E-revo -
10.31.2008, 12:24 AM
I have been looking for a couple smaller mAH 5s lipos for running with a parallel connection in an E-revo with MMM and Teckno Neu 1515/1y. I am Looking for quality Enerland Based cells and I have been looking (especially at NeuEnergy's because there on sale right now) but i haven't found anything that looks large enough capacity.
Anyone with any links or ideas?
Thanks
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
10.31.2008, 12:27 AM
How about running 2s and 3s in series? There's less complexity there, and weight distribution wouldn't necessarily be a problem, because you can mount the 2s on the ESC side and the 3s on the other side.
10.31.2008, 12:37 AM
That does sound like a possibility, ill look around and see what i can find. From what i have heard you must use cells of the same capacity, So a 3s 5000 and a 2s 5000 right?
Toys:
Slash with VXL
RC-Monster RC8T
10.31.2008, 12:39 AM
That is correct, when connecting LiPo packs together the capacity needs to be the same!
10.31.2008, 12:46 AM
K, so i found on Neu's site the 2s and 3s 4900xp for $67 and $95 respectively, pretty darn good deal, only thing is that they are their 25c batteries, will these be sufficient?? or should i go for smaller capacity 30c batteries?
Toys:
Slash with VXL
10.31.2008, 12:47 AM
Thanks
The only way you are getting a 5s lipo config in an erevo is if you do 2s 5000 on one side and 3s 5000 on the other in series to equal 5s 5000. You get the longest run time from a 4s 8000mah setup vs any other voltage/size due to the battery compartment restraints.. you can get close with some 3s 5000's in series for 6s 5000 total, but the 4s 8k setup gets you a few extra minutes vs the 6s 5k setup. You would need to find some 3s 5400mah packs to sneak past the 4s 8k setup, and even then they have to fit in the battery trays.. 26mm tall I think max. I suggest going 4s 5k w/ the elite 35c cells, they rock and are pretty cheap. 8k packs that fit include the maxamps 20c 8k packs, the SPC 15c 8k packs and the true-rc 8k packs all these 8k packs perform on par w/ each other so get the cheapest.
10.31.2008, 12:51 AM
will that 3s 4900 fit or is it too tall?
go to neu's car section and they have their 2s 5000 hard case packs on for 60.00 also... if you don't get your 5s to work out.
10.31.2008, 12:56 AM
I already have some descent 2s batts (polyquest 5000mAh 30c hardcase) i was just looking for a little bit more voltage without going to 6s, and i thought the battery compartments were 30mm high...ill have to check
Toys:
Slash with VXL
RC-Monster RC8T
10.31.2008, 12:57 AM
3s 4900xp fits no problem after you remove the spring on top of the battery box. 6s on that 1y is gonna be a bit extreme though. But if you do these cells should hold up just fine
10.31.2008, 01:03 AM
no i'm going for one 3s 4900xp and one 2s 4900xp for 5s 4900...so it wont be too high on the revs.
Toys:
Slash with VXL
Have you tried to fit a 30mm height pack? My MA 8k packs are 26mm and take up every last bit of the available height.. they even make the top bump up a little.... strange..
RC-Monster RC8T
10.31.2008, 01:07 AM
3s 4900xp is about 28mm high, pop out the spring on top and they fit easy. With the spring the chassis did have a bump.
10.31.2008, 01:15 AM
Just got out the trusty Digital calipers and sure enough they are 30mm on the dot
Toys:
Slash with VXL
10.31.2008, 01:21 AM
And how exactly do you guys feel about the 1y on 5s, which is just over 40,000 rpm, still well below the 60,000 max. Anyone here with any experience of this motor on 5s?
Toys:
Slash with VXL
RC-Monster RC8T
10.31.2008, 01:30 AM
Just been debating this in a different thread! It's my opinion that 6s is to much for the 1y, It can handle it yes but for how long and the temps will be higher than ideal and generally the optimal operating range is 35k +/- a few thousand. 5s is out of the optimal range in my opinion, the 1y is ideal for 4s. A 2.5d is better on 5-6s, it's actually freakish on 6s! At 25MPH it will still flip over if I punch it. This is all just my opinion.
