pasan
I <3 RC
pasan's Avatar
11.19.2008, 01:10 AM
To do what? I have currently done 74mph with a feigao 6s motor, 3s lipo and 25/55 gearing. That is the highest gearing I can achieve without making some custom stuff. I would like to see what I can do with the stock motor mount and spur before I get into modding stuff.
To go fast of course. A 9000Kv motor on 2S will require tremendous power to propel the TT-01 to high speeds. The stock spur is not 55, and how did you manage to fit in a 25T pinion with the stock motor mount? I remember I was pressed for clearance when fitting a 22T with the 55T spur.
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
11.19.2008, 01:20 AM
You can get a 55t spur for the tt-01. The same set of mount holes for the 22/58 fit the 25/55, as the spur is smaller in diamter.
I will stick with the hacker b50 5s (7400kv) on 3s lipo to do my session of runs. Getting cooler out here and everything runs faster in cold weather.
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.19.2008, 01:28 AM
I'v been running my B50 5s with 3s1p in my pan car geared 54/12. Both mm and motor stay cool enough.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
11.19.2008, 01:59 AM
:surpr ised:
pasan
I <3 RC
pasan's Avatar
I wish I were back in Alpharetta to take advantage of the cool weather. I have to deal with ~90F temps all year long :(
AX10 RTR - Stock :D
himalaya
himalaya's Avatar
11.19.2008, 03:36 AM
Get a 9000KV, PULL its Rotor out, insert into a 7700KV's can, Now you get a robost 7700.
I believe the 9000's ROTOR is where it values, should has some special material and technique like Kevlar wrap and temp-resistant magnet.
....What a Blue Sky....
Unsullied_Spy
Unsullied_Spy's Avatar
11.19.2008, 03:56 AM
Go with this and a 3s lipo pack almost 100,000 RPMs.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
11.19.2008, 04:06 AM
lol, nice web page by Castle
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
11.19.2008, 09:22 AM
Great for dragracing and speed records, but not much else. Meh.
emaxxnitro
emaxxnitro's Avatar
11.19.2008, 12:25 PM
if they can make a rotor stay together at that speed they should make a 2000kv 50volt motor
808E
pasan
I <3 RC
pasan's Avatar
11.19.2008, 01:53 PM
Don't the bearings have something to do with the maximum RPM of a motor? I can has magnetic bearings?
AX10 RTR - Stock :D
DickyT
11.19.2008, 02:05 PM
Maybe high grade ceramics? they can take considerably more punishment than a steel bearing.
11.19.2008, 03:05 PM
Is that lipo or a123?
ReV:-O
RC-Monster Carbon Fibre
11.19.2008, 04:15 PM
when i first got into brushless, i bought the novak GTB 3.5R system for my hpi pro 4, and that motor could go up to like 10,500 and that was agessss ago
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.19.2008, 04:18 PM
Forgot to mention that it is with A123. I'll build me a flat 4s1p A123 pack and see how that runs. That should be more like a 3s1p lipo pack under load.
But figure that under "drift mode" the rotor is spinning abit over 60K rpm.
