should I convert my savage
wayneb
should I convert my savage - 12.13.2008, 01:53 AM
I have been looking at the hpi savage flux this past week, and I have been thinking of building one myself. I have a nitro savage and a e-savage already so what I have been trying to decide is should I try to convert my nitro savage to a brushless or just start new and build a whole new brushless 1/8 scale savage. what would you guys do?
wayneb
12.14.2008, 05:12 PM
I'm thinking about converting my savage to a brushless system since I have a feigao brushless motor just collecting dus on teh floor or desk or wherever it gets moved to next. and since I can't get the engine in it to run anyway, I just thought of doing a 1/8 scale brushless. but I have a question. can I gear the motor to have less torque so that I can keep my three speed tranny in the truck for a little while? until the savage flux comes out. and then i can use the tranny from it in my savage. or lock my other two speed tranny?
Janezki
Avid Gear Crusher
Janezki's Avatar
12.15.2008, 05:01 AM
Gearing doesn't much effect the torque, use lower voltage if plan to have mercy on your tranny.
I presume that's an XL Feigao you have there, what is it's kv rate?
If you have a second tranny, then why not locking it - then you have reverse plus motor brake, depends from your ESC ofcourse.
wayneb
12.16.2008, 11:07 AM
the kv rating of my 8xl is 2084kv I think. what would I have to do to lock the savage two speed? do you have a link with pics of what to do?
12.16.2008, 11:13 AM
Actually, gearing does have quite an effect on torque. If the motor has say 0.3 fl-lbs of torque at the shaft for a given amperage, gearing down 20:1 increases the gearing factor, so it's 6ft-lbs of torque. Reducing the gearing (increasing the ratio) increases torque at the wheels.
Janezki
Avid Gear Crusher
Janezki's Avatar
12.16.2008, 12:38 PM
Oops.. I was thinking of torque that is effecting the transmission, but thanks for correcting me.
wayneb
12.16.2008, 10:29 PM
does anybody know what I have to do to lock the two speed tranny in second? any pics of it? thanks. also how big of motor will I need?
Janezki
Avid Gear Crusher
Janezki's Avatar
12.17.2008, 03:32 AM
There's a good thread about this few pages back, http://www.rc-monster.com/forum/showthread.php?t=13587
Scroll down to 9th post for info.
I thought you were using your 8XL Feigao? It should be allright.
wayneb
12.17.2008, 09:48 PM
If i use the 8xl that I have could I keep the two speed tranny? or would I have issues with it down the road.
Janezki
Avid Gear Crusher
Janezki's Avatar
12.18.2008, 02:51 PM
Idler & drive gear look slightly stronger on two speed, so it might even hold up.
I hopefully get rid of the transmisson problems when the Kershaw tranny is ready.
wayneb
12.19.2008, 01:02 AM
okay thanks janezki, I will give the two speed tranny a try and let you guys know how it works out. thanks again.
saydee1800
12.19.2008, 03:14 PM
I run a two speed in mine with no problem. But i DO HAVE DIFF problen
Maxamps Lipo's
FLM Savage 5s 5000
Mamba Monster V2
Feigao XL 10
E-Revo 4s 8000Novak HV 6.5
E-Maxx 4s 6000Novak HV 6.5
Speed-T 3s 5000
For Bashers, By Bashers - http://www.BigSquidRC.com
wayneb
12.22.2008, 11:05 PM
okay thanks, I guess it might be wise to wait until the savage flux comes out and then maybe I can use the tranny from it in my build.
