revo pinion
Balls-to-the-wa
revo pinion - 12.26.2008, 07:07 PM
I am converting my revo 3.3 to brushless and want to know what pinion to use, i am a newbie to electric, but not to rc's. I have ordered a feigao 7xl, and i am going to use a mmm v3, and zipp-h lipos ( 5000mah, 5s, 20-30c ). I will lock second gear, and the spur is a 38t. what pinion should i use if im going to race at a medium size track, and want to bash with some buddies. I can order a couple if i need.
George16
Supermaxx
George16's Avatar
12.26.2008, 11:20 PM
I'm currently using a 38/17 combo on my converted 3.3.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Balls-to-the-wa
12.26.2008, 11:49 PM
Did u lock second gear and what is the top speed?
Balls-to-the-wa
12.27.2008, 12:25 AM
o i also have a question for BrianG hehe how do i attach a fan to the motor, and what is the biggest one i can install on it.
George16
Supermaxx
George16's Avatar
12.27.2008, 02:05 AM
I installed the single speed conversion plate. I have not gps'ed it yet.
Revo with OS .18TZ
Balls-to-the-wa
12.27.2008, 09:08 PM
In order to get the best runtime out a truck what is the best way to gear it. Is it best to make it so the motor is undergeared, overgeared, or about perfect?
George16
Supermaxx
George16's Avatar
12.27.2008, 09:14 PM
It's best to have it in between. Undergearing and overgearing can be inefficient and can also cause high operating temps.
Revo with OS .18TZ
azjc
12.27.2008, 09:16 PM
the feigao will run pretty hot on 5s, I would suggest a 10XL
Balls-to-the-wa
12.27.2008, 09:17 PM
will that 17/38 gearing about right for my revo then, or will i need a different one. will a 5s 5000 mah 20-30c last longer than the 4s version in my truch?
Balls-to-the-wa
12.27.2008, 09:18 PM
sorry didnt see your post, i dont want to switch motors i already have the 7xl, i will pob swith it out later though
azjc
12.27.2008, 09:26 PM
Feigao 7XL will run hot in a Revo geared that high, you might want to run closer to 15/40, the Neu and Medusa motors have a much better design and will produce less heat
Balls-to-the-wa
12.27.2008, 09:27 PM
yeah i will prob switch do a nue after awhile, but 15/40 should be perfect for the 7xl , and will make it run as cool as a feigao can?
