Too Tight?!?!?! Kill me...
pedeboi364
Too Tight?!?!?! Kill me... - 01.22.2009, 09:43 PM
Ok guys, I bet this is a first... got a used T-maxx and one of the wheel nuts is too tight... i rly wana run it, but i need to switch around my cvds and shafts so i can run my truetrack... if anyone wants to offer a suggestion other than cutting it off, that'd be appreciated. If i gotta cut it off, anyone got an extra maxx stub axle??
Check out my FS thread in the General Discussion!! Help me go lipoly!!!
01.22.2009, 09:45 PM
Use a torque bar on your wrench. Is the nut stripped?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.23.2009, 12:19 AM
Yeah, is it stripped?
If you answered "YES" to the question above, CLICK HERE!
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.23.2009, 12:51 AM
Do you own a pair of vice grips? A small butane torch? Clamp vice grips on and apply heat to the nut while pulling on the vice grips. If that doesn't work try heating the nut up just enough to melt some of the nylon, when it hardens again it should form to the threads and you could twist it off. Another option is a drop of thin CA or green loctite. It should seep in and bond to the nylon, the bond with the nylon will be stronger than the bond to the steel and after it cures you should be able to get it off. Hope this helps!
Gee
A Horse's Ass
Gee's Avatar
01.23.2009, 04:10 AM
Not enough info on, but assuming that the nut is stripped. If you have a file or dremel you can flatten two sides so you can get a smaller wrench on it. If it in a deep pocket of a wheel like a velocity six rim. You can try a slightly smaller socket and place it on a driver and tap it onto the nut.
If the nut isn't stripped and the axle isn't turning then it sound like the stub axle has broken off. Need to find a way to get a hold of that stub axles while you are turning the nut.
Then again if you are putting your true track on it. May as well just remove the arms and drive shaft all in one swoop and that should give you a better view of the problem. That way you can tell us a little more then it just to tight.
Good Luck.
Thanks for the link what's_nitro
pedeboi364
01.23.2009, 08:31 PM
the nut is not stripped, but too tight for me to get off with pliers or a nice wrench... i only have a soldering iron, rotary tool, and a hammer :)
What's_nitro?
01.23.2009, 08:38 PM
That's impossible. Unless the previous owner used red loctite on it.... Wrenches are just going to slip off due to the wierd angle. Do you have a basic tool set with a socket that fits? Any size ratchet wrench (even the 1/4" ones) will give you enough torque to loosen that thing up. If you don't have any tools I would really recommend buying some. This isn't the only time you'll need them. I promise.
pedeboi364
01.23.2009, 09:41 PM
lol, ya. I need to get the wrench (chucked it at my sister a while back) but i'd say i'm in the market for some good support equipment with that pile of poo on my...pingpong table (workbench)
redshift
RC-Monster Square Tube
redshift's Avatar
01.23.2009, 09:50 PM
I use red loctite on all 4 of my wheel nuts- never had an issue- only did when I used blue as it wasn't enough.
Blue- temporary
Red- semi-permanent
Green- permanent
Green is normally used on bore & bush apps as an extra measure to secure a loose-ish press fit, but if indeed green was used then the only way out is a good butane or propane torch- which means you are out a wheel and axle carrier/ bearings at the least.
Without pics it's hard to be of much help.....
01.23.2009, 09:51 PM
Having the RIGHT tools is priceless. I cannot tell you the amount of time having the right tool has saved me.
pedeboi364
01.23.2009, 10:05 PM
lol, i need hex drivers too... huge LHS sale tomarrow gonna see what i can pick up, lipo and some odds and ends hopefully
redshift
redshift's Avatar
01.23.2009, 10:27 PM
huge LHS sale tomarrow gonna see what i can pick up...
Bring your truck!
Someone there worth their beans should be able to get your issue figured out.......
pedeboi364
01.23.2009, 10:30 PM
lol, just one guy in his later 70's... I should probably work there...
redshift
redshift's Avatar
01.23.2009, 10:36 PM
.....Even a customer might be of help- and hey you could be the geezer's successor- never know
pedeboi364
01.23.2009, 10:51 PM
:( they're closing in 3 months... and I've been smarter than all the customers so far too...
