Just curiouis are you all running for shock oil in your Revo
Just curiouis are you all running for shock oil in your Revo - 01.31.2009, 01:07 AM
I just purchased a Revo for a BL conversion and the shocks need some love...and was wondering what the bashers are using for shock oil as well as what spring set up you are using. The truck has the p2 rockers on it already. I plan on adding titanium turnbuckles and titanium pins and a few odds and ends.
I have this mount...http://www.rc-monster.com/proddetail...vomount&cat=33 and did a test fit w/my 9xl just for kicks, I will be getting a 70 series Medusa later to run in it, and noticed that once the pinion was lined up w/the spur, the shaft of the motor only was 3/4 the way thru the pinion. That being said, will I need long shank pinions for this set up? Again, I will be using the Medusa for this truck, NOT the 9xl.
Thanks for the help
Brian
George16
Supermaxx
George16's Avatar
01.31.2009, 01:49 AM
50wt all around, gold springs rear, and orange springs front with P2 rockers.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
01.31.2009, 09:54 AM
Are you happy w/your set up for the most part? Thank you for your input, much appreciated!
George16
Supermaxx
George16's Avatar
01.31.2009, 10:23 AM
Oh yeah. Or else I would have changed it already . It used to be blue springs rear and green springs front with 60wt oil but it was too stiff for my driving style.
Revo with OS .18TZ
01.31.2009, 01:10 PM
Thanks again...I will try this set up and see how it works!
