Budget intended conversion
Page 2 of 3
3
derek_18mt
02.11.2009, 04:48 PM
4s setup what kv motor?
derek_18mt
17
02.11.2009, 04:56 PM
Truggy/MT 2200kv 1515 1Y or 2000kv 70mm Medusa
Find all posts by Arct1k
18
02.11.2009, 04:59 PM
Around 2000kv
Visit BrianG's homepage!
Find all posts by BrianG
19
derek_18mt
02.11.2009, 05:02 PM
should i go with medusa or the mmm combo or the speed passion combo?
derek_18mt
20
02.11.2009, 05:08 PM
MMM combo IMO but I think you know that by now - LOL
21
derek_18mt
02.11.2009, 05:33 PM
ok one more question what about a novak hv esc and a medusa/neu 1512(only nue i can afford haha)
derek_18mt
22
02.11.2009, 05:37 PM
Nope. The Novak ESC needs a sensored motor. However, you could use a sensorless ESC with a sensored motor (just don't hook up the sensor wire).
23
derek_18mt
02.11.2009, 05:48 PM
is sensored better?
derek_18mt
24
02.11.2009, 05:55 PM
Only for realllllyyyy slow moving. Once the vehicle is over ~1mph, sensored has no advantage.
25
derek_18mt
02.11.2009, 06:07 PM
how does the novak 5.5 work in a truggy?
derek_18mt
26
02.11.2009, 06:08 PM
Too small unless you use really low gearing for speeds no more than 30mph IMO.
27
What's_nitro?
Soldermaster Extraordinaire
02.11.2009, 06:09 PM
Originally Posted by
derek_18mt
It doesn't. The
Novak HV
series can be used in 1/8 trucks, but thier motors are not nearly as powerful due to the smaller diameter rotor used.
Edit: Did you mean to say HV?
06:11 PM
What's_nitro?
Find all posts by What's_nitro?
28
derek_18mt
02.11.2009, 06:36 PM
should i run 4s or 6s?? srry for all the questions
derek_18mt
29
02.11.2009, 06:39 PM
Depends on your ESC. Can it handle 6s? You generally use a battery voltage as high as the ESC will support, and then a motor kv that will get you a total of ~35-40krpm.
30
derek_18mt
02.11.2009, 06:51 PM
What about a 8.5 2200kv motor (sensored) on 4s lipos setup with novak esc???
derek_18mt
Page 2 of 3
3
Linear Mode
Switch to Threaded Mode
