What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.23.2009, 01:36 AM
*evil laugh* Yesss!! Moooore screeewss!!!
I couldn't tell what was holding the motor on before, but that new setup looks sturdy.
GREYGHOST
02.23.2009, 04:46 AM
Outter limits.!!
Metallover
RC-Monster Spudgunner
Metallover's Avatar
02.23.2009, 07:23 PM
I just got a good run in with my crt .5 with 4s. Ambient was under freezing... Temps at the end were 105 for the motor and 100 for the MM and 25c Flightpower 3300mh lipos. The first 2/3 on the run was grass driving. The rest was on the street. I didn't let off the throttle much.
What's_nitro?
02.23.2009, 10:30 PM
That is the only thing I like about R/C in the winter. Nothing gets hot!
02.25.2009, 10:33 AM
Nice dude! Looks like you're enjoying the truck. I like your layout too, nice and clean.
Metallover
Metallover's Avatar
03.04.2009, 08:05 PM
I got some M2 gladiators today. Their huge! On the top speed estimator I got 35mph on 3s and 47mph on 4s. I am not getting that, but I bet it's within 10. With my new tires I got 50mph on 3s 67mph on 4s. I would bet this will be a good setup on 3s and it should bust 50mph on 4s with the new tires. I will do 4s for speed runs and bashing, and hopefully it doesn't get too hot.
I can't run them yet as I still need to get some 2.2 truck wheels, 12mm hexes, and a balance adapter. I'll post results and maybe even a vid.
Metallover
Metallover's Avatar
03.04.2009, 11:03 PM
I got to export the values from the speed calculator.
With 3s
Differential Ratio: 3.25
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 1
Pinion Tooth Count: 1
Total Voltage: 11.1
Motor KV: 1100
Tire Diameter (inches): 4.5.........(Gladiators)
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 1 : 1
Total Ratio: 3.25 : 1
Tire Circumference (inches): 14.14 inches (359.08 mm)
Total Motor Speed: 12210 RPM
Vehicle Speed: 50.3 mph (80.79 km/h)
Effective KV Value: 1100
KT constant: 1.23 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
With 4s
Other Ratio: 1
Spur Tooth Count: 1
Total Voltage: 14.8
Motor KV: 1100
Tire Diameter (inches): 4.5........(gladiators)
Motor coil Ω: 0
Total Motor Speed: 16280 RPM
Vehicle Speed: 67.06 mph (107.72 km/h)
I'm thinking 3s will be the highest I'll go with these tires and I'll save the 4s for larger cars. I'll have to try it tough because it would be fast as hell with 4s...
Metallover
Metallover's Avatar
03.06.2009, 11:34 AM
Here is another pic with the old tires. I'll probably refer to this in my sig. .... Or not.. It's too blurry. And godly bright.
Metallover
Metallover's Avatar
03.27.2009, 11:58 AM
I got some new wheels.. I also wish I could delete the post above.
Aceldama
Aceldama's Avatar
03.27.2009, 04:51 PM
That thing is bad looking, nice work.
Snipin_Willy
Snipin_Willy's Avatar
03.27.2009, 08:37 PM
I love my gladiators. You'll find out that weight of them spinning in the air with such a short wheel base make the truck back flip off of every jump. That's why I'm getting myself the RCM chassis.
Metallover
Metallover's Avatar
03.27.2009, 08:47 PM
Cool. I'm going to go for the 6 backflipper trickyyyy. Should be sweet.
I am awaiting a good power supply so I can charge my lipo and run this. Can't wait. The temps are pretty cold too. It was under freezing all day today. It was cold fishing and dunkball with a friend.... Real cold.
Metallover
Metallover's Avatar
04.08.2009, 08:35 PM
I got a nice run in today. I was running hard in my back yard on grass with a jump. I got some temps. 160f on the motor, 130 on the esc (bec enabled), and 95 on the battery. Speeds were great. I started with the battery half discharged from a run last night on pavement. Speeds were great, probably 35-45mph. I don't think 4s will work out too well with this motor... I would have to go back to my smaller tires.
here are some pics of the newly redone lipo. Big thanks to Linc for the re-do and big thanks to Overkill who sent me some labels free of charge! Thanks Guys!
It jumped and flew great. I could do backflips on demand. I got a little cogging, but it may have been just glitching from the radio. It is a little low on juice...
This is going to be a great basher this summer! I might race it a few times too...
