03.24.2009, 04:31 PM
The only difference between the 2.5 and 3.3 belts is the front and rear belts. The center is the same since it uses the same pulley size. The f/r small pulley went from 15T to 20T IIRC, so a larger belt is necessary.
You might want to just brace the chassis. I know that the belt had a ton of play on mine until I braced the chassis. If you push down on the center belt, you can actually see the chassis flexing.
This is true, I am thinking about the front and rear belts. I will rig some sort of brace up, I have a few ideas in my head, but will wait for the neu cells to come in before I do anything.
On another note, I destroyed the front belt just now... I guess I get to order a new one, or maybe check the LHS (waste of time usually). The stupid hole in the chassis at the front allowed a rock in and it jammed between the diff and the front upright/shock mount. I may add a hole in the front to allow debris out... Bad design not having a sealed front and rear belt setup... Maybe I can make something. I was thinking about a new chassis for the beast...
03.24.2009, 04:41 PM
Oooh, that sucks. Changing the front belt is a royal PITA.
03.24.2009, 05:07 PM
Yeah, I had the diff out last night, swapped it for a locked one that came with the car. I had to take out about a dozen screws, not as bad as a jato diff though (is anything that bad?)...
Takedown
WARNING: May become violent.
Takedown's Avatar
03.24.2009, 05:13 PM
Looks baller linc. Should make a good onroad basher.
RIP- Tammy (9/14/08)
Wild YFZ 450
yfz 450.
Wild YFZ 450's Avatar
03.24.2009, 06:12 PM
Its actually easy to change a jato diff.. You know you only have to take the back out right? Just take the back out where the battery box is its the 2 first screws on the bottom and then the 4 on the back.
  Send a message via AIM to Wild YFZ 450
03.24.2009, 06:24 PM
Yeah, I guess I meant the tranny when the idler and blows up. Still a pain compared to an electric rustler tranny.
Thanks Ryan, I can appreciate that remark as I am quite gangster myself.
Takedown
Takedown's Avatar
03.24.2009, 07:24 PM
I figured you'd say something like that if I mentioned 'baller'.
