Thread Tools Rating: Thread Rating: 24 votes, 4.83 average. Display Modes
Takedown
WARNING: May become violent.
Takedown's Avatar
03.26.2009, 08:42 PM
Check www.fsracingusa.com for the body's.
RIP- Tammy (9/14/08)
PedeBasher
PedeBasher's Avatar
03.27.2009, 12:16 PM
Heres an on-road body... http://www.fsracingusa.com/fsclearbody.aspx
Did you know?
  Send a message via AIM to PedeBasher
Takedown
Takedown's Avatar
03.27.2009, 12:30 PM
Also check www.OVERSIZERC.com
03.27.2009, 01:23 PM
Try the cen locker
SpeedAssault
SpeedAssault's Avatar
03.27.2009, 03:51 PM
thanks, I'll add that to my data base
affordable bodies,
I was just curious on other sources and styles
Originally Posted by PedeBasher View Post
yep thats cool looking, must be popular, it's out of stock
looks like just truck bodies
Try the cen locker
does that work ? I cant seem to find one. I also heard Cen is junk. I'll just make one
SpeedAssault
03.31.2009, 03:51 PM
Still running Locked Front and rear, It's a Blast to drive !
Running gear is double Revo drive Shafts
revo axle shafts
Emaxx centers with Spools
3S lipo
speed currently at 27mph
58 spur 21 p
Tons of power
crazy donuts on street
Awesome J turns -(throttle backwards then turn wheel and slide around forward and go
Upgrades Coming:
Custom Delrin A arm pins
Still trying to decide on battery, 4S , 5S or two 3S lipo ?? Suggestions
Mamba Max, later on a MGM
Losi aftershock -LST Center diffs, Front with HD Diff case and 7000k oil
Losi aftershock -LST center rear with locker/spool
Integy Revo Rear arms for Front and Rear Uppers
Losi 8ight or Ofna Front shocks
Name:	integy revo rr upr INTT3122S.jpg
SpeedAssault
04.06.2009, 02:49 AM
6S is too much for that motor - I would pre-order a a 70mm medusa in the sub 1600kv range with a MMM from Mike...
OK, what do I expect with above and with what lipo?
it's battery and motor time
I have read the tutorial but I'm confused what to get ?
Some help please
this Feigao is temporary
How to decide on motor , C amperage and voltage ?
I'm getting a MMM
Want speeds in the 55+ Or 60 but with lots of torque-
how do you figure this stuff ?
Remember this a 8-9 lb 4wd 20" wheelbase car
pinkpanda3310
pinkpanda3310's Avatar
04.06.2009, 08:16 AM
Sorry I dont know how to import it but there's a thread in brushless titled 'Is there a rule of thumb to work out motor amp draw' or something to that affect. B4maz posted a calc sheet for working out motor and power questions. It might help you, it helped me.
Takedown
Takedown's Avatar
04.06.2009, 12:40 PM
Cen is not junk by any means.
SpeedAssault
04.07.2009, 12:47 AM
starting to pull my hair
A little help here
Need a battery, doing lots of reading, but there never seems to be enough details, like in the setup thread, lacks aprox speed, tranny setups, amperage.
On the Tutorials by suicideden
1900-2700kv = 4s lipo
1700-2000kv = 5s lipo
1500-1900kv = 6s lipo
So does that mean I cant run 6S on a 2200 ?
can someone point to where you get these Nue motors at ? need to talk to a tech.
Castle said he did not recommend the MM combo with my setup.
I can only buy so much at one time, so battery is next, even though my 2383 Feigao is temp at least I have it.
Also read that "AM radios and BL dont mix" But I have no Problem with my 20yr old Airtronics 27mhz.
pinkpanda3310
04.07.2009, 09:46 AM
You'll need to decide what voltage your going to run then choose a motor with a kv rating to spin 30-35k.
pinkpanda3310
04.07.2009, 10:02 AM
The web page is no longer available so i took a picture of my print out.
SpeedAssault
04.07.2009, 12:53 PM
Wow thats cool, What does the red mean in your chart? is that optimal
I dont know where to start on what voltage to run, becuase I dont know what motor to run to get the speeds to 60mph.
price wise it looks like one 5S 5000 25C
or Two 3S at 15C each put in Series, would I need 2500's or two 5000's ?
Edit in later today
I guess I'll go with a castle 2200 motor ... so a 4S or 5S, castle tech was telling me, that with my setup a 4s should bring 40-55mph and a 5S 55-60mph , and if it's not hot bump up the gearing.
SpeedAssault
04.09.2009, 10:45 AM
Originally Posted by TDC57 View Post
You’re more than welcome we all help out each other whenever we can..
your MM will do great on 4s no worries, you might want to think about adding a fan and doing mods to it later.. Just a thought..
Jordan is you man on the Center diffs too.. here's link to them if you want or watch Ebay they have some XT8 and 808 center on there now of sale
http://www.amainhobbies.com/product_...oducts_id/8633
You will also need some of these..
http://www.amainhobbies.com/product_...oducts_id/8629 or Ebay for a better buy..
Best of luck again should be a fun build..
Bye the way thanks for the compliments..
For 4s I would recommend adding an extra Cap either the Novak HV 2700uf or similar.
You should also get an Ubec and the 5v fan is not a bad idea...
Hey guys, thanks again on info
I have been grabbing things to sell and put on ebay so I'm buying some 5s Lipos and a MMM
Spoke to Castle, recommended the 2200 motor and 4s for 45mph and 5s for 50+mph
going with Losi aftershock diffs with my own lock/spool, may use gorilla snwatt in front diff
putting in some Losi 2.0 truggy or 8ight front Shocks
and some integy Upper revo arms
also going to find a way to mount some 1/5 wheels
It's getting Exciting
04.09.2009, 11:47 AM
The castle 2200 motor on 5s lipo runs great in my friend's savage. Plenty of power. He runs a 4900 mah 25c 5s lipo, and it does fine. He is currently geared for about 42mph, but we had it geared for 55 and it did fine for a 5-8min run (had to stop as we were going to break stuff at that speed!).
