OK... So mini review time.
I put the slipperential in my truggy and went out to the local track this morning for some practice time and to see how this thing worked and how it effected the way the truggy drove.
I started off with the standard recommended setting of about 1.25mm gap between the plates on the slipper assembly. First lap with it and it was a noticeable difference. It made the very bottom end on take off from a stop or low speeds feel noticeably softer. I drove for the better part of a pack just trying to get a feel for how it reacted to hard launch conditions and the parts of the track that typically I used a quick snap of the throttle to clear a set of doubles and the hard acceleration out of the tight corners. It took a little getting used to at first, but after making an adjustment to my driving I got more comfortable with the feel.
I then pulled the truck off and did a quick temp test with my finger on the slipper assembly to see if was getting hot. It was for sure warm to the touch, but not as hot as the motor. (didn't have my temp gun in my pocket for that first run) But for sure didn't see any heat that concerned me.
After that first pack I started making adjustments loosening the slipper so it slipped more, and then adjusted it so it slipped more again until I had dialed so much slip into it and lost so much acceleration that I no longer could clear the triple on the back straight. It is a long triple. The nitros pretty much needed to land the small double right before it perfectly to set themselves up and get enough run up to clear it. Before dialing in all the slip I was actually easily able to overjump it with to hard of a throttle snap.
I figured that was about as loose as I could ever see anyone practically running it. I ran an entire pack thru it at this very loose setting trying to get a feel for it at this high slip setting. I also wanted to see how the clutch handled the high slip and what kind of heat would build up. After the pack (14-15 minutes) I quickly temped the slipper assembly and got a high reading of 116 degrees(F). Much cooler than I expected to see with running that much slip.
Next I started dialing back to the tight side with very little to no slip that I could detect. It basically felt just like it did with my normal diff. Tightening it down hard like that basically gave it no detectable slip at all I assume though that under a really hard hit like landing a jump with all 4 tires at the same time under throttle it would give just a bit and absorb some of the shock the motor would normally take.
Finally I spent a little time dialing it in to where it felt good to me. What I found that I liked might be a little more slip than what some others might want, but what I found it did for me was let me be more aggressive on the corner exits. With out the slipper I would have to carefully roll into the throttle coming out of the corner or risk having the back end break loose and step out on me. With the slipper set with just a bit of slip that corner exit became much less touchy. I did sacrifice a bit of the instant snap that would let you pretty much clear any jump on the track with no run up, but once I got the slip set where I liked it it seemed to be a good balance.
Thats about all I got to do with it today. A good little first try with it. So far I like it. Seems to be a solid unit that does just what its supposed to do. Looking forward to getting it on the track in a race condition so I can see if it actually helps with lap times. It seems like it will be a nice little tuning option. I can see it being very useful on the days where traction is low and having the smoothed out power curve on the bottom end will help keep everything in check.
So far so good Mike. Nice job.
(Crazy Side Note) After I got done playing with the slipperential in the truggy I took my buggy out for a few practice laps and wouldn't you know it... I broke the rotor loose from the motor shaft on my Neu.
Probably just one to many drivetrain shocks. Gonna have to get it repaired now and then get a slipperential for the buggy too so I don't do that again. Talk about timing.
I don't think Mike could have scripted that any better. LOL
