8ight Diffs
warbunny1
8ight Diffs - 03.29.2009, 02:15 PM
Are the diffs the same in an 8ight Buggy and an 8ight Truggy?
azjc
03.29.2009, 04:33 PM
yes most of the parts are the interchangable with the buggy and truugy
FG101C
03.29.2009, 05:08 PM
The ring gears for the buggy are 40 tooth and 43 tooth for the truggy. 13t pinion buggy, 10t pinion truggy, if thats also what you were wondering.
Ryu James
Ryu James's Avatar
03.31.2009, 03:21 AM
yeah, the diffs are very similar but dont try to switch them out. at first glance they look identical but they are slightly different in size and cannot be mixed. if you have a complete set of diffs and pinion gears for front and rear then that would work. just dont use the buggy diffs with truggy pinions or vice versa.
Jammin SCRT10 Neu 1512 1y
GO-RIDE.com
04.03.2009, 11:57 AM
The parts are exactly the same except for the ring gear and the spur gear. So, yes they are very interchangeable.
E-8ight - Tekin RX8 2000kv/4S
Thanks
warbunny1
Thanks - 04.03.2009, 10:11 PM
Thanks, that's the exact info I was looking for.
