kyosho buggy, how to mount battery trays
mjderstine
mjderstine's Avatar
kyosho buggy, how to mount battery trays - 04.02.2009, 09:57 AM
hey guys,
been looking around this site, and its been a long search on a good way to mount a battery tray to the Kyosho buggy chassis. the chassis gets so narrow at the front that its hard to mount a tray securely to the chassis.
can anyone give me some pics of their kyosho battery tray setup so that i can try to get some ideas for my own tray?
i want to get one of mikes trays, probably the longer tray, as to make sure i can fit all lengths of lipos in there.
my main issue with fitting it is that is wont be able to sit flush on the bottom of the chassis. part of it will need to go over the side guard. this will require somewhere around .25" of spacers when i mount a tray to the chassis.
my other question...
how exactly will a tray be mounted? will I be able to thread some 3 or 4mm screws into the bottom of the tray? or the other way around and thread some holes into the chassis?
thanks guys.
Nek
04.02.2009, 08:40 PM
Hey!
Well this no K car but this will give you a good idea on how to mount your RCM battery tray and what you can do to make it fit without using spacers.
http://www.rc-monster.com/forum/show...ght=808&page=4
You can mill the bottom of the tray so that the nuts or the sideguard wil fit inside the tray if you know what I mean. Anyway just check the bottom of that link, pics are worth a 1000 words :)
Hope it helps
mjderstine
mjderstine's Avatar
04.03.2009, 08:29 AM
i can see what was done to that one and it looks great.
how much material is there it work with on the bottom of the tray? how thick is it? 1/4" approx?
is that one bolted to the chassis using the side guard bolts?
Nek
04.03.2009, 04:26 PM
Looks like the side bolts are just going into the beveled area so that the tray sits flush, and it is secured using two others chassis holes, more towards the middle. He uses the larger holes he made where he can fit spacers.
No idea on how thick it is sorry...
