Medusa 028-56 V2 SE ?
himalaya
himalaya's Avatar
Medusa 028-56 V2 SE ? - 04.21.2009, 06:38 AM
I am planning on a Medusa MR-028-056-1900V2, a 28x56 size motor for my 580mm Vee boat, but the motor's centering hub is stopping me from this option, 'cause my motor mount has a center hole of 8mm but the motor center hub is 9.53mm in dia.
What's the real use of this hub ring-wall on front endbell casing?
I bought SE versions of the 3670 and 3680 V2s, and found the centering hub has been thankfully removed to have a flat front mounting plate. Will Medusa have a SE version also for its smaller brothers ?
....What a Blue Sky....
himalaya
himalaya's Avatar
04.21.2009, 06:49 AM
my 70 & 80mm Medusa, no centering hubs.
04.21.2009, 06:52 AM
Even it it does why not just make a small spacer disk to give you a flush fit?
04.21.2009, 10:59 PM
Or bore out the hole
Metallover
RC-Monster Spudgunner
Metallover's Avatar
04.29.2009, 06:23 PM
On my 60 it almost looks like that little mofo is useless, you could probably grind it off...
himalaya
himalaya's Avatar
05.05.2009, 06:18 AM
Thanks guys for your great ideas.
I was thinking of to drill it off with a big (10mm) drill bit, but this requires to remove the rotor while Medusa motors are not rebuildable design and may be damaged when forced open. Dremel/grind it off is another choice but may hurt the shaft by a minor mistake, the metal dust will likely kill the front bearing as well. Looks like to enlarge the hole on the motor mount or adding a spacer are the only ways to go.
05.05.2009, 10:35 AM
Get mike to make you a front cover like he does for the 36mm motors. Good idea as the al medusa uses for the front endbell is a bit soft and the threads are not the greatest either. If you plan to remove the motor frequently you need a front cover.
