05.13.2009, 04:36 PM
Nothing a sandblaster can't handle!
Thats about the best method to remove paint from thick metal. It does leave a slight texture on the metal. It may show thru the paint, so if you do not want that sand the chassis after you sandblast with 400 grit paper till it is smooth. You may also want to buy an etching primer that you can sand, that will make the final coat smoother as well. If you do plan to sand the primer you can skip sanding the chassis after you sandblast it.
05.13.2009, 05:16 PM
Nice color scheme! I like orange too:
Actually, that's not exactly my car, but I photoshopped a different pic so it looks as close as I can.
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.13.2009, 05:46 PM
I skipped over this thread several times figuring once you've seen a few revo conversions you've seen them all. Something told me to take a look and I am glad I did. That thing looks nice! Definitely something different for the tastebuds and probably the most interesting 3.3 conversion I have seen in a long time.
www.cubicle101.com
05.13.2009, 09:18 PM
Thanks for the tips...much appreciated!
05.13.2009, 09:20 PM
Thank you...This build may be taking a new turn since I posted this the other day. I am looking at a custom chassis being made for me that is 1.5" longer than stock and looks similar to the Gorilla Maxx set up. If I decide to go this route, I will have it powder coated orange.
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
05.13.2009, 09:30 PM
Powder coated!!!
05.13.2009, 09:33 PM
Originally Posted by ANGRY-ALIEN View Post
Powder coated!!!
YUP! I found someone local who will swap me some work for doing the chassis
TexasSP
TexasSP's Avatar
05.14.2009, 11:09 AM
Make sure when it goes to powder coating the edges are as clean as possible and try to get rid of hard corners. This is the only downside to powder coating is the it can chip in rough areas and hard corners.
Anodizing would work well too. I have a local guy that anodizes any color for 100 per batch, as much as you can fit.
www.cubicle101.com
05.14.2009, 04:33 PM
Good to know...thanks for the info, I will keep this in mind!
The Cow
The Cow's Avatar
05.14.2009, 09:32 PM
Great looking build! It is beautiful
Heath
"from deep within the barn doors"
** COWRC.COM **
RUSTY XL-5
RUSTY XL-5's Avatar
05.16.2009, 03:29 PM
I got your body today, should get quite a bit of it finished over the week/weekend.
I will spank a nitro any day...guaranteed. :)
Urgeoner
Urgeoner's Avatar
05.17.2009, 06:11 PM
That looks really nice Mag!
05.17.2009, 06:41 PM
I made 2 more custom mounting pieces....one for mounting the rx next to the steering servo and 1 on the other side on top of the unused existing steering servo mounts. The second piece makes a level mount for the esc to sit on. I will post pics. tomorrow when the paint is dry and they are mounted
05.17.2009, 06:42 PM
Thanks...all of the custom pieces should be dry and installed by next weekend...hopefully!
RUSTY XL-5
RUSTY XL-5's Avatar
05.18.2009, 06:29 PM
Magman wanted me to post a few pics of the progress of the body. Only 2 sneek peeks.
