Kcaz25
Kcaz25's Avatar
06.17.2009, 10:53 PM
Chad since you are no longer going with VBS on the Mutant SM (right?) Why don't you get GMaxx towers with real short shocks? Like Revo shocks?
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
06.17.2009, 11:29 PM
You know what, I actually thought about running either Duh Engineering Ti short towers or Gorillamaxx towers, and Ofna Ravager front shocks (identical to Supershocks, just shorter), so I could slam the body all the way down to get it as low as the bottom of the chassis.
-Chad
PM ME IF YOU HAVE THE BELOW:
Kcaz25
Kcaz25's Avatar
06.17.2009, 11:32 PM
Benfits being lower CG. Truggy killer. At truggy runner. Please do it!! I want to see what the Maxx platform still has up its sleeves.
Chadworkz
Chadworkz's Avatar
06.17.2009, 11:41 PM
Well, I just don't like the chassis and components showing under the body, so I want the body all the way down onto the chassis, for a perfectly clean look...low CG is just a bonus.
-Chad
Kcaz25
Kcaz25's Avatar
06.17.2009, 11:58 PM
Right slammed is only proper! Can't wait to see it RTR!
Chadworkz
Chadworkz's Avatar
06.18.2009, 12:35 AM
Me either! It will be finished first, unless I find a VBS within a week to finish the Super-G-Maxx!
-Chad
Chadworkz
Chadworkz's Avatar
06.18.2009, 08:23 PM
Racer-X, bearings, and hinge-pins came today...so progress is moving quickly!
-Chad
Kcaz25
Kcaz25's Avatar
06.19.2009, 12:18 AM
Chad you really need to do something bout a/the build thread.
Chadworkz
Chadworkz's Avatar
06.19.2009, 04:55 AM
Well...I am still collecting parts, so when I have them all, I will start a build thread for each truck.
Right now, all I need for the Super-G-Maxx is; VBS, UE 6mm steel CVDs, center drive shafts, UE diff outputs for my Ofna 8-spider diffs, Dace 23mm hex-adapters, and a body. Then, sometime after it is finished and running, I am going to replace the transmission (E-Maxx trans with Gorillamaxx single-speed conversion & OTB GenIII idler and 2nd gears) with a custom center-diff/motor-mount that I am going to make.
All I need for the Super-Mutant-Maxx is; UE Racer-X rear carriers & upper arms, UE 6mm Ti CVDs (Lito has a set for me, but he can't ship them until he comes back from deployment), Duh Engineering Ti shock towers & Ofna Ravager front shocks (for the slammed body), UE diff outputs for my Ofna 8-spider diffs, Dace 23mm hex-adapters, Boca full-ceramic bearings (races, balls, & spacers are all ceramic), and a body.
I think that's it.
-Chad
George16
Supermaxx
George16's Avatar
06.19.2009, 05:31 AM
Chad, I'll sell you the 6mm UE titanium cvds, 23mm Dace adapters,UE diff outputs for 8 spyder diffs, and center drive shafts and UE drive cups if you can wait until I return from deployment in September.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Chadworkz
Chadworkz's Avatar
06.19.2009, 06:21 AM
Lito, you are the man, sir...I really appreciate everything you have done for me, and I accept your latest offer. Is there any chance you have a full set of UE springs? Actually, do you have two sets of everything you listed, plus a set of real Supershocks?
Also, do you know what length center shafts the Gorillamaxx G2 chassis with UE Monoblock uses? I am REALLY hoping there are UE Ti center shafts that will work, because I absolutely love them!
Thanks for everything, man, and thanks for any help you can provide about the above questions...I really appreciate it.
-Chad
Chadworkz
Chadworkz's Avatar
06.20.2009, 08:19 PM
Welp, add a third Supermaxx to my build sheet, except this one is going to be nitro! I haven't had a nitro truck since about 2007, so I decided to build another one, and I might as well make it a Supermaxx!
I just bought a like-new UE Thunder chassis kit about an hour ago, and am going to slap a new LRP ZR.30 X Competition engine (with shaft-start) on it, plus all of the other UE Supermaxx parts for it...minus VBS.
Here is how I am going to outfit it:
[1] UE Thunder chassis, braces, center skid, Ti driveshafts, BB motor mounts, servo mounts, tank mounts, fuel tank, and antenna mount.
[2] RC Solutions 1.075mm spring-steel F&R skids (lighter than 3mm aluminum, lighter & stronger than 2mm titanium)
[3] UE Ultralite diff cases
[4] Ofna 6-spider diffs with UE outputs
[5] Hardcore Racing F&R bulkheads
[6] Great Assembly (GA) bulkhead braces
[7] UE Knucklehead shock towers
[8] Ofna Ravager rear shocks (identical to Supershocks, just a little longer)
[9] UE 6mm shock stand-offs
[10] UE Racer-X suspension
[11] UE Racer-X Setback lower rear arms (real ones)
[12] UE Racer-X Hi-Impact lower front arms (real ones)
[13] UE 6mm steel CVD axles
[14] Dace Mfg. 23mm hex-adapters
[15] Lunsford Racing titanium hinge-pins
[16] UE GenIV servo-saver steering system
[17] UE Progressive/Dual-Rate shock springs
[18] UE titanium front turnbuckles
[19] Traxxas 2.5 black transmission
[21] OTB input, 1st & 2nd gears
[22] UE Super6 FOC gears
[23] UE 4-shoe clutch system
[24] Strobe slipper system
[25] CNR dual-disc brake kit
[26] JConcepts wing on MBX-5T wing-stay
[27] Diemaker Dave wing-mount
[28] JConcepts Rulux ½" off-set Half-Ups
[29] Pro-Line LPR Bow-Ties
[30] Pro-Line Crowd Pleaser Revo 3.3 body
[31] Tony's Screws
[32] Acer Ceramic bearings kit
I think that's all...
-Chad
Kcaz25
Kcaz25's Avatar
06.20.2009, 09:40 PM
[31] Tony's Screws
I love it, I really do. But the reason I said that you need to create a build thread(s) a few days ago was because even if this thread is long in the tooth its still not your thread or the place. Oh and UE is making 8mm CVDs again!!
Chadworkz
Chadworkz's Avatar
06.20.2009, 10:30 PM
That's true, sorry to the OP...I will stop posting here.
-Chad
