06.17.2009, 11:41 AM
Vandal. Was it the original shaft with a cup attached, or one of Mikes shafts that lets you use other cups etc?
06.23.2009, 04:15 PM
well after shimming the diffs so it has a tight mesh i havnt been having problems with the spider gears stripping or breaking , but now i noticed that my car tends to go to the right under hard acceleration , its not from the steering i think it m8 be from the diffs , wat could be causing this problem ??
06.24.2009, 06:04 PM
Torque steer ftw!
If it wasnt doing it before though, I would check over the steering and the toe-links to make sure everything is right & proper in those departments.
Mine does the same though, its just a natural thing as the truck leans to one side under power- like the way a txt-1 does only not as bad.
JERRY2KONE SUPERMAXX
Engineering. -
06.24.2009, 09:41 PM
Engineering wise that is somewhat natural due to the torsional twisting effect of the motor because it is mounted from front to rear in the vehicle. It should not be too noticable though being that the vehicle is pretty small. In 1:1 dragsters it can actually throw the car into the wall due to this physical act of mechanical nature if it is not compensated for. It sounds to me like since you shimmed the diff properly you have a very tight setup that is near perfect, casuing the vehicel to pull to one side.
06.24.2009, 11:30 PM
Some guys on the TRX forum actually had the same problem after installing those diffs I dont remember what they did about it. I'm pretty sure there is more to this than torque steer.
07.26.2009, 02:36 PM
well im still having diff problems , they usually last 2 weeks then strip , i think it m8 me cause of 3 things , either its because 1)its too heavy (FULL flm parts arms chassis shock towers .....) 2) the diffs i used were from an ofna titan , used infernop and a non brand chinese diff so it m8 me cause the diffs i used r weak 3) coz im using ofna titan cups with spacers
the solution to the first is buy flextek arms and g4 chassis , for the second is buy lightning hardened diffs , for the third is buy the adapter to use emaxx cups
wat do u think is the problem , anyone used to have the same issues ?
thanks
NeuMaxx
07.26.2009, 03:12 PM
Not sure about the weight issues. Alot of us have heavy trucks without a problem. Just be done with it and get the HP buggy diffs and you will be fine. I have beat the snot out of my truck without a problem.
08.01.2009, 04:24 AM
well i just ordered a set of hardened spider gears from the hot bodies lightning to try it cause i coudnt afford the full set cause i had to get some other stuff for my other RCs , but can anyone help me on how to shim the spider gears , cause im not sure of the way i do it
11.12.2010, 06:24 AM
Hey with those ejector pins, can you put them into the lower front bulk cause wouldn't they rub on the steering turnbuckles?
THANKS!@
I just want to know how many to buy >:)
Ejector pins -
11.12.2010, 07:43 AM
If you are talking about the ejector pins being used for hinge pins, then yes. I have mine cut flush on both ends so they do not interfer with anything at all. The first set that I cut I left the ball ends on and inserted them from the front. That way there is no possible way for them to come out, because the bumpers keep them in place. When I purchased mine I ordered 8 of the 14" pins so I would have plenty of spares. We do have six SuperMaxx trucks though, plus two stocker trucks. If you are using the RCM Hybrid diff/bulks they will work just fine. I also tapped out the setscrew holes to use a bigger setscrew for holding the pins in place. Those little tiny ones strip out way too easy for my liking.
11.12.2010, 08:55 AM
Ok great to know. So i pretty much have a turbocharged stock truck (allu bulks etc…) without the setscrew thingo will 8 ejector pins be fine to fit 1 truck?
Thank you
One pin -
11.12.2010, 09:05 AM
Thank you
You can probably do all four corners with one 14" pin, but for the price I would get a few pins so you have back up spares. They are easy to cut with a Dremal tool using a cutoff wheel. I usually grind a divit into the pins where teh setscrews seat, and then you are good to go.
11.13.2010, 06:44 PM
I just want to know if you know what is better between the straight ejector pins and the through hardened straight pins :O
THANKS~
Through hardened. -
11.13.2010, 08:39 PM
Most who are using them are getting the through hardened pins. The reason for using these over lets say the Lunsford titanium pins is that they are hardened steel and do not bend. Removing bent pins can be a real PITA. They hold up much better with little wear, and I have yet to hear about anyone breaking them. There is a thread in here some place about them, along with a link to the site where you can order them.
Here they are. http://www.plastixs.com/ep03.html
Reason: ADDING INFO
