roofles.
06.18.2009, 09:39 PM
My motor plate recently stripped, and need a new one to replace it.
I will also need a 3mm (I think, whatever shaft is on the Castle Creations 4600kV motor), 26T pinion.
Let me know if you have anything!
06.18.2009, 09:55 PM
I have a motor plate that has longer holes but works. i also have a 48p 28t pinion for 1/8th shaft (the 4600) IM me
roofles.
06.18.2009, 10:18 PM
IM'd ya :)
06.20.2009, 01:59 AM
Anyone have a set of 17mm truggy wheels and tires in decent shape? I spun a hub on 1 set and wore down another...
06.20.2009, 03:59 AM
I have a knuckle sandwich for you shamcow!
A 16yr old with a combover
06.20.2009, 11:30 AM
anybody have 2.2" rims with 12mm hex?(for a rustler)
It doesnt matter if they have tires or not
06.20.2009, 11:37 AM
read the PIF thread...
06.20.2009, 08:51 PM
I need a e-rustler front shock tower/body mount, and e-rustler battery hold-down.
Multi Tasking
06.20.2009, 08:54 PM
Anyone have any center diff oil?
06.21.2009, 09:06 AM
I have 10k
roofles.
06.22.2009, 08:45 PM
Need some 45A powerpole contacts:
Well, I bought 2 Turnigy's...
Turns out they use big freaking wires.. 10GA, what the hell.
So I bought a 15 pack of 30A PowerPoles awhile ago, and got both of them today.
Would've been a PERFECT day today, if only I would've gotten the 45As..
So if anyone has any extra 45A contacts, PM me!
I have some white, tons of it, heatshrink for trade :]
06.30.2009, 02:36 PM
rawfuls: 45amp powerpoles? on lipos that can push more than that, sounds like the powerpoles will limit your performance...
anyways, I am looking to find some sort of low voltage indicator or cutoff, for 2s, 3s and 6s, if it does not work with all lipos... If anybody has anything, it will be going on the barbie jeep. thanks!
roofles.
06.30.2009, 02:37 PM
According to kulang, he has used 30A on his lipos and 6S, and the connectors don't even get warm.
06.30.2009, 05:34 PM
ok, I was just going from the numbers... And I forgot to say I was also looking for some hyperion balance taps too
Never Fast Enough
06.30.2009, 06:04 PM
Correct. I don't think those Amp ratings apply to our application. I've pushed 180A spikes through the 30A connectors and they didn't even get warm.
