Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Kcaz25
Kcaz25's Avatar
07.08.2009, 01:42 PM
Yes. It does void the warranty.
I figured. Thanx man!
Are there any 23mm rims that are offset that fit Maxx size tires wheels not 40 series. I'm asking because the ones I have now seen above don't fit the badlands very well. The badlands slump over to one side and stay that way (until the turn back the other way) espcially when turning at speed.
Thanx guys!
-Zack
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.08.2009, 01:57 PM
Not sure if these are standard or 1/2" offset but the price is to cheap to pass up.
http://cgi.ebay.com/Pro-Line-23mm-Ve...lenotsupported
This seller has THE BEST Prices on wheels and tires on the Net ! I bought 5 sets a couple months ago and now there even cheaper ?!
07.08.2009, 02:07 PM
Damn bondo! 4 LPR premounts $32 plus shipping!!!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.08.2009, 02:28 PM
Hey I wouldn't Bullshit you guys ??
Thanks to that rotten prick Trevor I have 4 sets of tires I'll will not use for a couple years because I have so dam many sets to wear out first.
Bo-Hoo for me ;-)
nitrostarter
nitrostarter's Avatar
I dont see them for $32 but i see 4 for $40...
N. Rustler conversion
07.08.2009, 02:30 PM
Just realized 4x for $32 is tires only...
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.08.2009, 02:33 PM
You need to check all the auctions prior to comitting because there may be different listings for the same item for a much different price.
07.08.2009, 02:47 PM
There is/are...
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.08.2009, 02:58 PM
I couldn't resist looking around for another deal when I noticed this;
"Note: The seller of this item is away until July 13, 2009. You may purchase the item, but there may be a delay in processing your order."
Kcaz25
Kcaz25's Avatar
07.08.2009, 03:04 PM
You know what? I think I have proline maxx size wheels! I bought them back in 06 or 07 and can't remember. Has anybody else noticed the slump?
Thanx for all the help!
Rivermaxx
07.08.2009, 03:08 PM
Thanx guys!
-Zack
What foams are you running?
Kcaz25
Kcaz25's Avatar
07.08.2009, 03:22 PM
Ones that came with either the tires or the wheels...?
I guess some one needs to tell me that they have had succes with a particular 23mm off set wheel foam combo on badlands. and or help me identify what wheels foams I have.
Rivermaxx
07.08.2009, 03:31 PM
Are they the molded ones ? if not thats probably the problem or you need stiffer molded foams. The older non molded foams disenergrate inside the tire after a while dont ever use them. I am not sure how good the molded foams that come with the tires now.
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
07.08.2009, 06:36 PM
The Badlands do that "shift" from side to side on any MT/3.2" wheel, no matter what foam is being used. You can fix the problem by mounting the tires on the inner-most bead lip of the wheel, or by mounting them on LPR or Half-Ups wheels. If you need 23mm hexes, you will need to find a 3.7" to 4" 17mm wheel, like from Ofna.
-Chad
PM ME IF YOU HAVE THE BELOW:
Kcaz25
Kcaz25's Avatar
07.08.2009, 06:52 PM
River, I didn't know that about the foams thanks!
Bummer. Cool. Are you talking about adapters Chad? Won't the 17mm still be my weak point? What is best LRP or Half-Ups?
