Erevocanuck
07.12.2009, 06:35 PM
How long have you been using that dean connector?Older plugs can cause more resistance.You could also try Astro Flight Zero Loss Connector
J57ltr
07.12.2009, 06:39 PM
The link you posted was for some DDR memory, but I looked it up and the specs are lower than Deans. They state that they have less resistance than an equiv. piece of 14 gauge, Deans lists the same as 12Ga.
Jeff
Snipin_Willy
Snipin_Willy's Avatar
07.12.2009, 08:46 PM
The plug I'm using (was using) on my ESC wasn't too old. And it wasn't getting noticeably hot, certainly no warmer than the battery. I'll do some testing when I get my MMM fixed up and back in play.
Erevocanuck
07.13.2009, 02:23 AM
Jeff
LOL to many window open at the same time . My good pc is in the shop being fixed & I was thinking of getting a new one.Link fixed now
florianz
07.13.2009, 05:22 AM
hi,
you can continue guessing...
...or go to this page, it might be the answer for your questions (it's NOT a shop):
http://www.elektromodellflug.de/hoch...romstecker.htm
it's in german, but at least you can read the figures.
I would call this guy a guru regarding RC-Electronics (chargers, batteries etc).
I have just ordered myself some golden 5,5mm plugs, and some fat 6 mm˛ cables (especially for motor-esc).
flo
Byte
07.13.2009, 05:35 AM
Originally Posted by florianz View Post
hi,
flo
Let's all buy Lehner gold connectors!
Resistance: <0,05mOhm
Continious: >250A
florianz
07.13.2009, 05:57 AM
Continious: >250A
yeah, and after that I'm broke & cant't afford lipos...
the 5,5 mm bullet plugs I've bought are affordable, u get them for around eur 2,60 a pair.
but yes, it's worth to invest in good connectors.
Byte
07.13.2009, 06:03 AM
They cost 3 euro for 1 pair
I never gonna buy such expensive connectors. For me: "Wannabe/Chinese" Deans and Hobbycity 5.5mm Goldconnectors
florianz
07.13.2009, 06:09 AM
they're the plugs for the motor cables. for the batts I keep deans, at the moment. I 've learned that the real "deans" are better then the chinese copies.
I want the plugs this week and not by September... I' don't order 4 bullet plugs in HK...
littlegiant
07.13.2009, 06:52 AM
The real deans are gold plated. The copies aren't. Maybe this explains y the real deans are better?
littlegiant
07.13.2009, 07:08 AM
These plugs look exactly like those zero loss plugs for audio speakers that i have used more than ten years back.
florianz
07.13.2009, 07:12 AM
yep, and the metal spring/the thing that tightens the fit, is also different. the chinese has a "flat" one, the deans has a "curve", which are easier to plug in. after 2 years of use, the deans have lost their gold plating. I think there are different qualities within "chinese" deans. left the chinese, right the original (at least I think so...):
Mentat
Brushless Mentat
Mentat's Avatar
07.13.2009, 12:13 PM
bullet connectors all the way! 6.5mm can hold 200amps
FS: 8ight-t Race Roller TONS of UPGRADES
8ight 1.0 & 2.0 | 8ight-T 1.0 & 2.0 | E-Revo BL Edition | T-Maxx | Slash | Raze-ST | XXX-NT Drake | 3PKS | DX3S Telemetry
Snipin_Willy
07.13.2009, 12:42 PM
The biggest concern I have with bullet connectors as battery connection is that even if you heat shrink them they will never be as safe from shorting as deans/trx plugs. Only way to solve this is to find some type of plastic casing that the bullet plugs fit into, similar to the HC Turnigy packs
07.13.2009, 12:45 PM
That's what EC3 and EC5 connectors are...
