Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
Ryu James
Ryu James's Avatar
07.19.2009, 06:31 AM
ok, so i got my camera working again. here are some pics of recent work on the 1/5.
modded bumper. looks much more like truggy bumper.
redcat35
picked up a set of chrome spoke wheels.
redcat34
here are the integy disc brakes. coming along nice but not done yet. cant wait to get these all hoooked up.
redcat33
redcat32
set of modded baja 5b shocks on the rear. baja front shocks to come this week. these are 10x better than the rampage shocks and have a huge 6mm shock shaft for super strength.
redcat31
used a set of kyosho big bore shock boots as dog bone boots. these work much better than the huge HPI or Darksoul boots they sell for this.
shockbootRR
so this week should be a good week. i am anticipating getting my motor mount and spur gear back from the machine shop, my Hydra hv240 arrives, and a few other things that i plan to get done. i am hoping to have something that is starting to resemble a finished truck by next week. we'll see.
Jammin SCRT10 Neu 1512 1y
florianz
07.19.2009, 06:42 AM
looks great!!
I am curious how the breaks are.
Ryu James
Ryu James's Avatar
07.19.2009, 01:07 PM
Originally Posted by florianz View Post
looks great!!
i can tell already they should work great. just with one mounted up i can roll the truck and pull the cable manually and the pads grab the disc firmly and stop the truck. i think they will stop this beast on a dime. i have to make some new discs though cuz these are 24mm and meant for the baja whereas the rampage has 22mm hexes. so i have some 2mm carbon coming this week to make my own brake discs.
florianz
07.19.2009, 02:44 PM
carbon fiber brake discs, cool. do you have to balance the break-power or does that work automatically? I remember that from eg. old landrover, when the mechanical breaks are not well adjusted, the car turns right or left when breaking.
Ryu James
Ryu James's Avatar
07.19.2009, 07:12 PM
because the center diff is locked on this truck that wont happen. technically i could only run one set of breaks and it "should" work. if i do notice anything like that though i can adjust the grab of brakes to be equal all around by adjusting the width of the pads so that all 4 grab at roughly the same time. i really wish i had a viscous center diff and could then dial in front and rear bias. i am doing the the 4-wheel brakes now even though they are not needed cuz i hope to build a viscous center diff at some point in the future. i guess it will depend mostly on how i like the locked center diff.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.20.2009, 12:03 AM
Lookin' good man.. lookin' good...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Overdriven
Destroyer of Tires
Overdriven's Avatar
07.20.2009, 09:22 AM
Very nice, I'm jealous. And I wanna see a closeup of the brakes without the disc. I'm curious where the mounting holes lined up.
With your brake bias, your right you don't have to worry front to rear right now. But you do have to worry about left to right, as there is a diff between them. If it is off it'll probably be most noticable when you first apply the breaks, or when applying light to moderate pressure. The solid center diff will help even things out alot, as each wheel is not as independant. With your skills I'm sure it'll be setup pretty close on the bench either way. Keep it up
KaztheMinotaur
KaztheMinotaur's Avatar
07.20.2009, 06:25 PM
I got my 2215 today and "it's so big !"
07.20.2009, 07:31 PM
wow. great work. Look forward to the end result
07.20.2009, 07:39 PM
Originally Posted by KaztheMinotaur View Post
"it's so big !"
Are you dreaming or did someone actually verify this
SnoopMaxx
SnoopMaxx's Avatar
07.20.2009, 07:46 PM
Photo PLZ
Morten SnoopMaxx
Never to old to play
c",)
KaztheMinotaur
07.20.2009, 08:15 PM
Well that is what my wife said anyway...
aqwut
aqwut's Avatar
07.21.2009, 09:25 AM
LOL.. Post us a photo Kaz.. .... I want to see this BAM motor with a hand model...
KaztheMinotaur
07.21.2009, 09:46 AM
Here you go. Shown with a crank case bearing from a 30.5cc engine.
finfin
07.21.2009, 11:29 AM
one question.
Does phoenix hv 110 be enough with Neu 2215 2y and 12s A123 ?
