J57ltr
07.14.2009, 09:54 PM
Wouldn't have any pics would you? I totally removed the screw and it's stuck like there is something else there maybe rust on a shaft?
Thanks
Jeff
07.14.2009, 11:04 PM
Possibly. I don't have any pics but I can say it's the weakest clutch I've ever seen.
07.24.2009, 01:50 PM
I figure I should update this thread. IT RUNS!!!!
Well, it's not finished, but it turns the rear wheel...
Here's the secondary jackshaft sprocket. Had to be heavily modded to mesh with the chain properly, keyed and mounted to the jackshaft:
Jackshaft completed:
Here she is:
Ignore the fuel tank how it's mounted. Just did that so I could test the motor, and make sure I had no binding.
I also made some seat stiffeners, but I will get pics of those tomorrow or sunday. I hope you enjoy it.
J57ltr
07.24.2009, 07:13 PM
That looks great! Cant wait to see it completed. Are you itching to ride it?
Jeff
07.24.2009, 10:29 PM
Thanks Jeff! Yeah, I am excited to ride it. I just need to order a throttle, and spend a few hours on it, and it'll be done!
08.03.2009, 02:55 PM
More progress!
Had to cover the motor in plastic and a wet towel to shield it from welding sparks/heat.
Welded on 1" squarestock for brace for centre frame brace. Bent/welded centre brace.
Bent/welded rear frame braces:
Made a bracket to conform to the fuel tank- welded it, and hoseclamped the gas tank to it, with rubber guards.
08.06.2009, 01:24 AM
Come on throttle!! We need you!
J57ltr
08.06.2009, 01:57 AM
Well I am sure you could get an old bike cable brake assembly and use it for the time being. Be interesting getting used to stopping
Jeff
08.06.2009, 02:06 AM
That was my original plan... But I found this throttle for 13 bucks shipped and ordered it, not gonna break the bank eh? Had no idea this Dbag was gonna be so SLOW! He should know that the 12th is my absolute deadline!
It lives!
It lives! - 08.11.2009, 01:00 AM
Holy shit, I got alot done in 3 hours...
Throttle I got off ebay:
Needed a brake cable tension adjuster, found one on a old bike I had laying around.
Needed a end for the brake cable so I made one out of some 1/4" brass tubing, and soldered it to the cable.
Cable installed on the brake lever:
Had to make a guide for the brake cable:
Welded it on:
Can you guess what this is?
You might have guessed right:
Brakes hooked up on the rear:
Throttle return/connector I made:
All together:
Metallover
RC-Monster Spudgunner
Metallover's Avatar
08.11.2009, 01:08 AM
wow, got me confused.
Guess you should edit that before someone quotes you
Looks great. Is it ready to ride yet?
And btw, not calling you out, we all need to work on keeping the profanity down.
08.11.2009, 01:11 AM
Yeah, my photobucket is weird like that, I copy 1 img link and it links to another. All fixed now. I can ride it, still needs a couple things done (need to dremel out ignition hole for kill switch) and then it'll be officially done. I didn't have time today to ride it though- worked to the very minute i had to leave.
08.11.2009, 10:46 AM
That looks like it'll be alot of fun when its finished.
08.11.2009, 12:30 PM
Yeah, I hope so. Thanks for looking Neil!
