Best setup on or offroading is 70wt oils all around, variable dampening installed with #2 pistons and Blue rear sliver front springs. If you don't jump much or just hit really small jumps you may want to run 60wt oils, but if you have big old jumps around like I do you'll love the 70wt oils w/ vdr
Hmm.. The truck has Integy rocker arms installed.. I see there are long-travel rockers available.. which of course makes a lot of sense, given my desire for less crashing into the ground...
Does anyone have any idea which one's these are? P1, P2?
my e-revo doing alot of nose diving ... im using the LONG TRAVEL ROCKERS AND PUSHROD SPACERS with front silver and rear blue spring on 60wt oil on all corner and Varable Damping Piston #2 and the valve on top ... I cant really see how to fix this ...
When the truck is nose down in the air give it some throttle, the spinning tires will help bring the nose up
When the truck in nose up in the air give it some brake, slowing the tire spin will force the nose down.
I had the blue springs on the back mine and didn't care how it sprang the rear up, went to silvers front and back and she jumps sweet now (for me and my application?)
