PBO
RC-Unobtainium
PBO's Avatar
09.16.2009, 08:03 PM
You need a pump not a vacuum cleaner, you'll burn the vacuum out in a few hours
Have a look at this link http://www.instructables.com/id/Vacuum-bagging-basics./ kind of how we do things (I work with boats) but the lamination/prepreg is relatively easy, getting the vacuum pump system working properly can be a bit fiddly for the first time
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
whitrzac
Can't catch this...
whitrzac's Avatar
09.16.2009, 10:52 PM
that looks an aful lot like using a "foodsaver" vac sealing thingy...
pb4ugo
09.17.2009, 09:00 AM
A real vacuum pump WILL out perform the Foodsaver. The Foodsaver just works really well for the money. Besides, I think PBO was just responding to your idea of those storage bags that you vacuum (with a Hoover) the air out of.
whitrzac
Can't catch this...
whitrzac's Avatar
09.23.2009, 08:15 AM
creative juices flowing again
what about a"hybred" chassis???? alloy front part with kickup and CF the rest of the way. think old RC10 cars
pb4ugo
09.23.2009, 08:57 AM
That would work. Mill both the CF and the aluminum to 1/2 thickness (or bend the aluminum to accept the CF in the bend--ship-lap style) and use some Scotch Weld 2216 at the joint. Make the joint under the steering posts so it's clamped together as well.
Kind of makes you see why the RC10 Graphite had the kick-up molded in
sabongi
09.23.2009, 12:01 PM
i thought about that days ago... if you can't bend carbon fiber, use aluminum!
I´m planning on doing a cf chassis for my d8, but the front part it´s bent upwards, so why not use both???
rchippie
rchippie's Avatar
09.23.2009, 08:17 PM
That is basically what MR comstructor does with some of his chassis . But it just looks so much better when it's all one piece.
REAL MEN RUN BRUSHLESS
whitrzac
Can't catch this...
whitrzac's Avatar
10.22.2009, 08:07 PM
bringing this thread back up...
whats the best way to cut CF???
I have access too
dremal: mabey the multisaw atachment, or carbide bit??
hacksaw: blades??
bandsaw: IDK if the teeth will last
CNC router: only has 1/2in collet and bits are $$$$$$
mabet a CNC mill too
my personal thought was the dremal multisaw attachment, and a realy fine blade....
pb4ugo
10.22.2009, 08:21 PM
The cnc router with a diamond bit designed for fiberglass would be the ultimate. Whatever method you choose (and they'll all work about the same, other than the cnc) make sure you wear proper breathing protection. Carbon dust is NASTY stuff.
Rivermaxx
10.22.2009, 08:45 PM
I used a band saw with a fine tooth blade and it worked awesome.
whitrzac
Can't catch this...
whitrzac's Avatar
10.22.2009, 10:31 PM
the problem with the band saw is, its in the "wood" shop part of the teched lab, and blades are $45 each. would there be any problems with it geting into the dust colector??
any links to a router bit?
pb4ugo
10.22.2009, 10:58 PM
Here's a 1/4" one: http://cgi.ebay.com/J-L-TOOLS-1-4-FI...#ht_2325wt_941
Spend a couple minutes on google and you'll be able to find 1/8" bits too.
whitrzac
Can't catch this...
whitrzac's Avatar
10.23.2009, 12:03 AM
so somthing like this?
http://www.micromark.com/FISH-TAIL-R...ign=GoogleBase
pb4ugo
10.23.2009, 12:21 AM
Yah, those would be fine. Or:
http://www.icctool.com/webdoc105.htm
and: http://www.drillsandcutters.com/firo.html
