Originally Posted by superek4
I was thinking 6s 2650mah@40c vs 6s 3000mah@40c becoz of the height diff between 36mm vs 41mm.
Small track draw less amps vs big track? Is it becoz less full throttle? How long can your 6s 2600 Mah batt last you? 12-15mins? Wats was the per cell voltage remaining?
Yes, much less time at full throttle. My local track has only one long straight where you can get full throttle. I usually have near 3.7v/cell as I have never actually hit the LVC with this car yet.
Originally Posted by BrianG
Since he's using 2600mAh cells and comsumes about 200mAh/min, he can run around 13 minutes.
I have run about 12 to 15 min: 10 min main with a few warm up laps and sometimes a little playing after, still yet to hit the LVC though. After 7 min. qualifier I use 1200 - 1600 mah, 10 min. main uses about 1800 - 2300 mah
Buggy races allow 6s? I know china restrict 1/8 Ep buggies on 4s.
Local race series allows any batteries, they do have a 4s limit for the regional series that comes around a couple times a year.
Originally Posted by auto2
u think 6s in a buggy would make it too punchy and hard to drive smooth?
With proper kv motor, it is no different than 4s, except you do get a bit more punch since the voltage drops less under acceleration. Also, everything runs super cool.
