Cutting and drilling a Hyper 7 chassis.
Bazzokajoe
Cutting and drilling a Hyper 7 chassis. - 01.12.2010, 03:49 PM
Hey guys,
just looking for a few tips on cutting my chassis,
as most of you guys probably already know the chassis is 7075 aluminium
i am intending on cutting another hole for my spur gear, as in flipping my centre differential around,
as this will give me two possible places to mount my motor (behind the servo or next to it)
I have access to a pillar drill and dremmel but no milling equipment, i am intending it to look good, or at least neat :P
if you dont really get what i am trying to do just say so, i re read that and i cant even understand it :S
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.12.2010, 04:50 PM
If your intent on making a slot in the chassis, drill the inside perimitter of the hole with a 1/8" drill bit till the chunk falls out and finish with a metal file. Shouldn't take but 15-20 miutes and a couple beers.
JThiessen
JThiessen's Avatar
01.12.2010, 09:08 PM
Scribe your lines on it with a utility knife, then use your dremel to cut as close to the lines as you can. Then use a fine file to finish the slot. You can also just use a drill for the extreme ends of the slot (use a drill the same dia as the slot is going to be).
I use these wheels on my dremel - works much better than the standard ones. http://www.amazon.com/Dremel-EZ456-2...3344771&sr=1-4
They also come in a kit
http://www.amazon.com/Dremel-EZ406-C...3344771&sr=1-7
thzero
01.12.2010, 10:25 PM
Those are the ones I've used to cut aluminum. I have also found the version for plastic works well on thick lexan bodies.
01.12.2010, 10:44 PM
That's almost $2 a wheel!!! Do they work that much better?? I know I hate changing wheels, so the convenience is definitely a plus.
JThiessen
JThiessen's Avatar
01.12.2010, 11:00 PM
In a nut shell - yes. I used to go through 2 or 3 wheels per cut job. Now I change wheels about every 4th or 5th job.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.12.2010, 11:11 PM
However you do it make sure that you drill a hole in the corners. 90 degree corners are weak spots asking for problems, plus the radiused corners look better. It's not a big area that needs to be removed so if it was me I would drill two holes, one at each end of the slot, pick a bit that is slightly wider than the spur gear and then use a dremel to remove the material between the holes
01.12.2010, 11:59 PM
sweet, thanks
01.13.2010, 12:23 AM
+1. That's exactly what I would do...
Bazzokajoe
01.13.2010, 03:02 AM
cool cheers guys :)
now i have another question... when converting to electric do any of you fill in the nasty nitro holes (flywheel/engine mounts?)
if so... with what?
01.13.2010, 03:52 AM
Originally Posted by Bazzokajoe View Post
cool cheers guys :)
if so... with what?
I have never seen the holes filled...........
Bazzokajoe
01.13.2010, 09:54 AM
ahh ok, i just thought it would probably look alot better , i guess i will see next week, when all my parts are supposed to be arriving :)
Fast5sRevo88
01.13.2010, 04:39 PM
http://www.amazon.com/Dremel-EZ406-C...3344771&sr=1-7[/QUOTE]
Are these better than the fiberglass reinforced ones?
JThiessen
JThiessen's Avatar
01.13.2010, 08:04 PM
I'm not certain which ones you are referring to? I've only used the ones I linked to and the standard little brown ones that come with most dremels.
Fast5sRevo88
01.13.2010, 08:32 PM
I was referring to the ones that are about 2" round, they are brown, but they have a fiberglass webbing on them.
