Originally Posted by Sneeck
Why would you need a 14xl for a center diff?
See, it's all in the reduction. An EMaxx tranny setup gives you a final gear ratio of 1:20ish, and if you use a buggy center diff, you'll get something like 1:10ish. (thus needing a "slower" motor)
Of course it depends on what center diff setup you want to use. If you incorporate a diff into a maxx tranny, the numbers will be different than a buggy diff. When in doubt, just count the teeth :)
If you need help, just give us the FGR.
35mph is a realistic speed for 16 cells.
