swiftneed
swiftneed's Avatar
Unhappy 03.19.2010, 06:28 PM
Strange I am doing my xt8 conversion and the bottom of the chassis hits the diff when i tighten the diff rear to chassis, when I loosen it, I can then move the shaft? what gives
swiftneed
swiftneed's Avatar
03.19.2010, 07:04 PM
OOPS suicideneil figured out before I inspected it thouroughly I set the diff the opposite way and not into the groove in the chassis oops and gotta get it done I want the 1717 castle
jhautz
jhautz's Avatar
03.19.2010, 08:29 PM
Glad you figured it out
to make it...
or break it...
Silent...But Deadly
swiftneed
swiftneed's Avatar
03.21.2010, 01:58 PM
Now what the center diff is hitting what did i miss ?
swiftneed
swiftneed's Avatar
03.21.2010, 02:25 PM
Bottom of diff original xray to xt8 havent even put it together yet and its already bottomed outOK gurus what gives Suicideneil probably already knows
ID:	8692   Click image for larger version
03.21.2010, 02:31 PM
Hard to tell from those photos- use the macro setting ( little flower ) to get a good in-focus close up. I'd also go ahead and intall the rest of the unit to see if it rubs anywhere else, but I'd definately say that spur looks huge- what tooth count is it?
swiftneed
swiftneed's Avatar
03.21.2010, 02:35 PM
Scratch on the RCM chassis from not putting the diff in the correct way OOPS the other day what the hey first build> ok thats what the grooved area is for LOLthats bottom part is my leg since you guys are quick to pick apart lol
ID:	8694   Click image for larger version
swiftneed
swiftneed's Avatar
03.21.2010, 02:49 PM
48T original maybe I should get RCM slipper
swiftneed
swiftneed's Avatar
03.21.2010, 03:25 PM
After further extreme close observation reailize the bracket with the square goes under the center diff to give clearance and the build continues
ID:	8697   Click image for larger version
03.21.2010, 03:34 PM
Oh well, figured it out in the I guess.
swiftneed
swiftneed's Avatar
03.21.2010, 03:52 PM
Yeah thanks sometimes you have to step away to realize a break a beer ok a shot
swiftneed
swiftneed's Avatar
03.21.2010, 11:26 PM
Is the Rear supposed to have a little droop
jhautz
jhautz's Avatar
03.21.2010, 11:46 PM
both the front and rear should have some droop.
to make it...
or break it...
Silent...But Deadly
swiftneed
swiftneed's Avatar
03.22.2010, 06:12 PM
Can I use UE supershocks on my xt8 whats your opinion?
jhautz
jhautz's Avatar
03.22.2010, 07:04 PM
Save your money. The UE shocks aren't any better than the xray shocks.
to make it...
or break it...
Silent...But Deadly
