IS THERE ANY HOPE----READ!!!!!!!!plz -
02.16.2006, 08:23 PM
:026: :026: :026: i have by accidently took off my engin head and there was a goey seal of some kind..i did not take it offf...now i think theres no compression? is there a problem is my engin done...i didn't screw in the screws to my head because 2 are striped so if i screwed the back in would it work...people in rc-monster fourms help me out!!!:026: :035: so if i screwed my 2 screws back in tight would there be compression? is my engine done? i hope its good still and theres still hope:032: :026:
02.16.2006, 08:27 PM
if any one! any one can help me and tell me what to do and how to fix it plz
pl when you reply that you stay on topic plz i need to find out!
HELP!:'(
02.16.2006, 09:06 PM
noe one can help me?
come onn
02.16.2006, 09:53 PM
A stripped screw for a head don't sound good. I don't know if you can fix it. You would need to get all the screws to hold the head down for it to work properly.
Peace!
Country
Help support the
Rc-Monster
Buy here
02.16.2006, 09:57 PM
yep - and if you get all the screws tight - and you can spin the flywheel easily by hand - then the compression is not good - also - it will loose all low end grunt - if its got no compression - you either need a new piston and sleeve - or a new motor - sorry to be the bearer of bad news..
Hows that "Hope and Change" working out for Ya???
02.16.2006, 10:24 PM
That is a problem hotncold. I don't think he can tighten all the screws up. He has some stripped. I don't know what you do to that. You may get a heli put in it. Get the stripped threads fixed.
Peace!
Country
Help support the
Rc-Monster
Buy here
02.16.2006, 10:29 PM
Thats a tough one - if possible - retap and resize screws - thats about the only thing i can think of - is the motor very $$$$ - if not - it may not be worth it - also - if 2 of the screws are able to be tightened - then i think that if it is still easily spun ( flywheel ) then she is still shot - stripped screws or not -
02.16.2006, 10:31 PM
No, he got out the stripped screws, he just didnt want to run with them in there..
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
02.17.2006, 11:28 AM
ya if i replaced all four you it be alright?
like when you plug start it you hear a hiss like its escapeing..beacuse they are not screwed back in properly....so if i take all four screws out and replace em and screw in the good / new ones tightly it should be fine?
02.17.2006, 01:18 PM
Oh! I thought you stripped the block part. I would put all four back in it and tighten down properly. Then check the compression. It is not going to seal if no tight. Have to do that and try it let us know how it goes.
Peace!
Country
Help support the
Rc-Monster
Buy here
02.17.2006, 04:49 PM
yup
im just waiting in for some stainless steal srews..its coming with evry screw for my truck so once that comes in ill info all you into whats wrong...
im so glad its nothing else but the screw head.:D its nothing to do with the piston and the piston sleeve because it was running perfectly the other day so..im glad its all good now!
02.17.2006, 05:12 PM
all i did was take off the head to take a look..i was supposed to switch heads but im just going to stick with the old square head for now i was going to get a round blue head of slvester but it had no head shim so ill just stick with what i have
heads -
02.17.2006, 06:04 PM
this is what i mean
I
I
I
02.19.2006, 07:56 PM
its all good :D i got a new head i ither go big and new or go home!
thanks to slvester for the head!!!!:D heres some pics
a nice blue round head
SCREW SQUARE HEADS!:018:
02.19.2006, 08:15 PM
No problem , mike! Now wheres my money? :D
Losi 8ight e
