Go Back   RC-Monster Forums > Support Forums > CORR Trucks - Slash, SCRT10, etc.
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.15.2010, 03:16 PM
In stock trim they run fine on 3s but use BrianG speed calc to gear conservatively because the motor tends to get hot. Get a heat sink also.
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
06.19.2010, 02:28 AM
I agree with whoever said it, either put some sand-paddles on the front of that thing and make some deflectors to double-side tape to the body to keep the sand out of the internals of the truck, or at least run the sand-blades on the front...the front is rarely on the ground anyway, and with the blades, you will get MUCH better steering, and have zero wheel-speed difference issues.
-Chad
PM ME IF YOU HAVE THE BELOW:
phatmonk
RC carbon junkie
phatmonk's Avatar
06.27.2010, 10:38 AM
Whats the best shock position/setup for lowering the Slash 4X4 for onroad speed runs.Just move the shocks to the outside mounting position?I have Pro-line powerstroke shocks.
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.27.2010, 10:55 AM
YUP, And add at least 8oz of weight to the front. With stock body I couldn't get it over 60mph with it getting airborne.
I put on a Losi dirt oval body and clicked off 2 runs back to back at 84mph.
Third run my 1509 NEU's magnet let go
phatmonk
RC carbon junkie
phatmonk's Avatar
06.27.2010, 11:02 AM
Thanks.I am runnin a MMM CC Neu 2650 on 4s.Just gotta be aware of the massive power it has because we all know its gonna be hard on the drivetrain.It actually snapped the front axles.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.27.2010, 11:07 AM
I was running 5s with the 1509 till she popped. A 2650 on 4s will be the next power plant experiment myself, should be entertaining ??!!
Nick
COOKIES!
Nick's Avatar
06.30.2010, 06:04 PM
I've been running the MMM2200kv on 3s, with 16/40t gearing.
Mad power! Nice and quick to. :D Love it.
~ Nick.
bruce750i
bruce750i's Avatar
06.30.2010, 06:12 PM
^Don't look now, but your foam is hanging out.^
84 Mph very nice Bondo! Looks like that dirt O body was the ticket.
Nick
COOKIES!
Nick's Avatar
07.09.2010, 12:42 PM
Here's mine. :)
~ Nick.
reno911
Smelly Nitro meet your maker!
reno911's Avatar
08.20.2010, 11:06 AM
So I just picked up another Slash 4x4 on RCTech. This thing will have one purpose and that purpose is to compete with Nick here and see how much of the truck will survive on 30+ ft jumps and ridiculous bashing.
Semi Pro
Semi Pro's Avatar
08.28.2010, 08:42 PM
lots of great info in here guys
i ordered my slash 4x4 last night (standard not pe) as well as a set of front and rear tekno cvd's, some rpm arms,Traxxas Hardened Steel Front Drive Hub,and a King Headz Traxxas Slash 4x4 Slipper Bearing Adapter
does anyone know where i can find the Kings Heads motor mount in stock?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.28.2010, 09:21 PM
As awesome as the RPM arms are I think they and CVD's don't mix, the arms have a ton of Flex.
Example: I run a asphault Slash oval class with Latemodel bodys and foam tires, I had to ditch the RPM arms because I was eating up tires due to the high traction flex. Went back to stockers and tire prob was solved.
Don't be surprised after your first real crash the axle looks like bananna, hope I'm wrong ?
Semi Pro
Semi Pro's Avatar
08.28.2010, 11:01 PM
i had them on my 2wd slash and my rustle with cvd's without any problems, we will see if i do crash it up bad and bend a cvd i will be happy to tell you guys you were right
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.29.2010, 08:27 AM
The 4wd is quit a bit heavier, again I hope I'm wrong.
Semi Pro
Semi Pro's Avatar
08.29.2010, 02:53 PM
lol my 4wd will be 1lb or so lighter than my 2wd, i ran a MA 20c 8000mah 3s2p in my 2wd and im going to be running a Hyperion 45c 5000mah 2s1p in the 4wd
my what we learn is just a few short years
