Team Pie 420
The Dude
11.16.2010, 08:16 AM
SO how long until castle make full sized vehicle controllers and help me set of the electric conversion market on full sized? :P
This is such awesomeness imo.
Pdelcast
Pdelcast's Avatar
11.16.2010, 01:34 PM
Originally Posted by Desert Rc View Post
Only 8s....really? I thought at least 10s was expected out of this XL esc.
XL HV version (up to 12S) coming in spring...
Patrick del Castillo
President, Principle Engineer
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.16.2010, 01:38 PM
Woot!
Any idea when / if a blower will be produced for the 2028?
Pdelcast
Pdelcast's Avatar
11.16.2010, 01:51 PM
Yes -- a blower with 2 x 40mm fans will be available at the same time as the 2028 (and will ship with the Baja conversion combo...)
Finnster
KillaHurtz
Finnster's Avatar
11.16.2010, 02:52 PM
Can you estimate the price spread between the XL HV version and the 8S XL version about to be released?
Will the HV XL version have the same current handling capability, or a lower-current/higher V capability for the same approx power output?
Thanks!
Pdelcast
Pdelcast's Avatar
11.16.2010, 02:58 PM
Thanks!
The HV will have a lower current, higher voltage -- just like you said -- yields similar power output, but at higher voltage.
thanx!
Patrick
Finnster
KillaHurtz
Finnster's Avatar
11.16.2010, 03:01 PM
Thanks for the quick reply Patrick. :)
Also, I can't find any info on the footprint of the esc anywhere yet. Does anyone have any specs? I know Chris has been playing w/ one...
Need to plan a place for it in my ongoing savage conversion. I want to cut a plate for the electronics next, and don't know how big a space to make for it :)
Pdelcast
Pdelcast's Avatar
11.16.2010, 03:07 PM
Footprint is the same as the ICE-200 air controller. The heat sink is different, but shares the same footprint.
Technical drawing:
http://www.castlecreations.com/suppo...ix_Ice_200.pdf
crazyjr
crazyjr's Avatar
11.16.2010, 03:43 PM
Patrick, Will it be opto or will it have a BEC? I believe last time it was said it was going to be opto. Thanks
Pdelcast
Pdelcast's Avatar
11.16.2010, 03:45 PM
The 8S controller has a switching 5A BEC (with programmable output voltage,) the 12S controller is opto.
Thanx!
Finnster
KillaHurtz
Finnster's Avatar
11.16.2010, 05:16 PM
Specs from the pdf PdC linked:
Length:3.94” (100mm)
Width:2.04” (52mm)
Height":1.2” (30.6mm)
Weight:4.56 oz* (129.4g*)
Max amps:200 amps**
5 amp BEC
Max volts:34 volts (8s LiPo/22 cells NiCad/NiMh)
Thanks
NickRummy
NickRummy's Avatar
11.16.2010, 05:51 PM
Patrick,
Do you now if the conversion kit will include a pinion and if so, what tooth count?
Pdelcast
Pdelcast's Avatar
11.16.2010, 05:57 PM
Originally Posted by NickRummy View Post
Patrick,
Yes I do know that.
It will include a pinion -- 14 tooth. We will have option pinions of 12tooth, 16tooth and 18tooth.
Thanx!
Patrick
NickRummy
NickRummy's Avatar
11.16.2010, 06:24 PM
Thanks! Any specs on the battery holder(s)? I have my 2 4s 5000 packs waiting.
