03.03.2006, 04:45 PM
On another thread, captain was having diff in installing his dif's. Are there any out there that are strong that don't need so much modifying? and still cost effective?
03.03.2006, 05:30 PM
I have the flm hybirds and ofna diffs. It was put together operation. I didn't have to mod nothing.
03.03.2006, 05:43 PM
thanks sounds good, are they tough enough, and what if i wanted to go duel bl later?
03.03.2006, 05:46 PM
Also, did you go to 6 spyder? or 8 spyder, when u say ofna i'm assuming that's what you are referring to...
03.03.2006, 05:56 PM
I got a 8 spyder diff made by ofna. You don't need a dual brushless system. One good system will out perform and run longer than a dual. I have zero problems with the set up. I run the ue 6 spyders and the ofna 8 spyder setup with no problems.
RC-MONSTER BRUSHLESS FANATIC
03.04.2006, 12:11 AM
thanks for the reply guys so $240 for both the front and rear is not bad at all by the way,does the mip cvds ok with them?
03.04.2006, 03:37 AM
MIP and UE cvd's are one of te few that work with the 1/8th diffs. So, that is a yes.. ;)
03.04.2006, 07:09 AM
If your worried about twisting diffs and the such - might wanna consider the 8mm cvd's - plus they are a little longer - so no chance of the cvd popping out of the diff cup.. just my .02
Hows that "Hope and Change" working out for Ya???
03.04.2006, 08:42 AM
where can i get info on 8mm cvd? thanks
03.04.2006, 10:10 AM
Mike can get them for you.
Is it true H&C? are these 8mm's longer?
03.04.2006, 12:33 PM
I don't think they are longer than the mip. They are alot better made and stronger though. My brother had a mip break on him and he didn't even jump it. He only had a puny 8L on it.
