neweuser
neweuser's Avatar
03.03.2006, 04:45 PM
On another thread, captain was having diff in installing his dif's. Are there any out there that are strong that don't need so much modifying? and still cost effective?
coolhandcountry
coolhandcountry's Avatar
03.03.2006, 05:30 PM
I have the flm hybirds and ofna diffs. It was put together operation. I didn't have to mod nothing.
neweuser
neweuser's Avatar
03.03.2006, 05:43 PM
thanks sounds good, are they tough enough, and what if i wanted to go duel bl later?
neweuser
neweuser's Avatar
03.03.2006, 05:46 PM
Also, did you go to 6 spyder? or 8 spyder, when u say ofna i'm assuming that's what you are referring to...
coolhandcountry
03.03.2006, 05:56 PM
I got a 8 spyder diff made by ofna. You don't need a dual brushless system. One good system will out perform and run longer than a dual. I have zero problems with the set up. I run the ue 6 spyders and the ofna 8 spyder setup with no problems.
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
03.04.2006, 12:11 AM
thanks for the reply guys so $240 for both the front and rear is not bad at all by the way,does the mip cvds ok with them?
Serum
Serum's Avatar
03.04.2006, 03:37 AM
MIP and UE cvd's are one of te few that work with the 1/8th diffs. So, that is a yes.. ;)
HotnCold
HotnCold's Avatar
03.04.2006, 07:09 AM
If your worried about twisting diffs and the such - might wanna consider the 8mm cvd's - plus they are a little longer - so no chance of the cvd popping out of the diff cup.. just my .02
Hows that "Hope and Change" working out for Ya???
luvsrc
luvsrc's Avatar
03.04.2006, 08:42 AM
where can i get info on 8mm cvd? thanks
Serum
Serum's Avatar
03.04.2006, 10:10 AM
Mike can get them for you.
Is it true H&C? are these 8mm's longer?
coolhandcountry
03.04.2006, 12:33 PM
I don't think they are longer than the mip. They are alot better made and stronger though. My brother had a mip break on him and he didn't even jump it. He only had a puny 8L on it.
