Knez
Knez's Avatar
01.05.2011, 09:24 PM
I laso have the Integy XL carriers and can say they come with shaft that fit perfect!
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
01.05.2011, 11:17 PM
Alsright, got some good pics of the hubs now, thanks for those guys!
On to shocks. Keep in mind this project has changed to a 19" WB MT that will likely run a set of super bolt on tires with half offset 40 series wheels. Gives me about 18" width.
So what should I use for shocks? Currently have the 8 "small bores" that came with the X SS kit. I do not mind going to other brands, but would like to keep the costs down, as I am cheap.
I will get a weight on everything tomorrow, might help with shock selection.
thzero
01.05.2011, 11:37 PM
4 Flux shocks. Use either one of the following springs:
#86553 SHOCK SPRING 18x80x1.8mm 12.5 COILS (WHIT 159gF/mm)
#86554 SHOCK SPRING 18x80x1.8mm 11.5 COILS (YEL 177gF/mm)
Standard Flux spring is
#86551 SHOCK SPRING 18x80x1.8mm 14.5 COILS (PINK 134gF/mm)
You can pick up the Flux shocks on ebay pretty cheap; granted not as cheap as the older Savage shocks, but oh well.
Freezebyte
01.06.2011, 01:06 PM
Originally Posted by josh9mille View Post
Can you show pics of the used chrome vs the used stock black ones?
01.06.2011, 02:39 PM
Looks like the shocks will run about 10 bucks each shipped. I am guessing the stock springs will be a bit weak? I will weigh my truck and you can tell me if the white or yellow springs will be better. I plan to bash it so I am guessing the yellow will be the way to go.
_dV
01.06.2011, 06:50 PM
Depending on weight, if you use the long plastic tube and just the one spring on each shock you may find the pink spring is fine. That's what I am using but my build is a couple hundred grams lighter than a stock Flux (about 3730gm without wheels, battery, shell).
If you use the yellow spring with the tubes it will be very stiff.
01.06.2011, 07:01 PM
I will try just a set of the flux shocks. Maybe add thicker fluid to them. What weight is the stock fluid? Would it be a good idea to tear them down and rebuild with some green slime? If I have to dump the fluid...might as well go all they way.
Freezebyte
01.06.2011, 09:06 PM
I tried 40wt in FB2 but found it to be too stiff so I went back to 30wt and used green slime
Jahay
02.23.2011, 04:12 PM
Originally Posted by V0RT3X View Post
You can get these: (or someone from the UK can post them to you)
http://cgi.ebay.co.uk/HPI-86376-SUSP...-/160506095635
I really need a set of these...
hpi 86376 hinge pins
Does anyone know who stocks them or has left over stock???
I couldnt find them on the bay!
or maybe sells their pins individually?
