Originally Posted by What's_nitro?
Umm since running them higher has no effect why would you want to? The switching circuit (if present) would keep the servo at full output regardless of input voltage. That is good.
I already run my 7980s on 7.8v I believe and it makes a difference in both speed and power, I was hoping you could do the same to these. With a CCbec input voltage is requlated anyway. The only time power should vary is running a receiver pack which in my opinion should be a thing of the past.
BrianG if I had $150 just floating around I'd do some real world testing of the 7950 equivalent to the 7980, see how it compares. I can stall the later reasonably easily on the high grip rock I crawl on.
Kieren
