Closed Thread
HPI Baja 5b SS Roller, Lauterbacher Clutch, Turtle Racing Complete Clutch System, DD
Wild YFZ 450
yfz 450.
Wild YFZ 450's Avatar
HPI Baja 5b SS Roller, Lauterbacher Clutch, Turtle Racing Complete Clutch System, DD - 04.20.2011, 01:49 PM
For sale here is my HPi baja 5b SS that I built not to long ago, I am Selling it as a roller.Perfect for a electric conversion or all you need is a complete engine/exhaust, the gear plate and spur gear mount set along with your receiver and transmitter and it will be good to go. It has the gas tank, Stock Steering servo , Futaba 3305 servo for throttle, It will also come with a HPI 6v 3000mah battery. Also the On/Off switch was moved to the top instead of the bottom.
Pro -Line Desperado Wheels with Bow-ties all around, Rear are basically brand new Fronts have some use. It has DS Open Wheel nuts, RPM arms all around. GH Aluminum Front Bulkhead, GH Front aluminum shock supports, Ram-tech front shock tower, Metal Final gear in the servo long with the servo arm, It also has a fine mesh on the sides of the chassis to keep stuff from getting in there. It also comes with a Gas tank died black that will also come with a Red anodized DDM Gas cap. It has a carbon fiber roof plate along with the TGN Billet Spark Plug Cover, Also comes with a Hostile 57t Spur gear in good condition along with a practically new stock one. It also has the gear cover with the hostile Red pins. It has GH aluminum shock tower supports along with a GH rear shock tower brace. Also has Killer Bee limiting straps all around and a HBZ Black Rear Bumper. Just about all of the parts were de anodized and sanded then polished. I also tapped the front wheel hexes to use a Screw and washer instead of a C-clip, I had to shave a bit a of the RPM arms off but they still hold up just fine. Also if you would like any pictures of anything please let me know. I wll take Paypal only, PM If interested in anything.
It will also come with a Team Phatdad Engine brace, Good condition but the right side screw stripped out so the edge is a bit beat up from using a dremel to remove it.
Up Next is a DDM Dominator V1 Black pipe, It is in good condition no bends just a few scratches.
Here is a HPI Light kit with 4 lights and 2 Y splitters so you can run all four lights off of it.
Up next is a Lauterbacher 4 shoe clutch in good condition lots of life left, It will come with the bolt needed to mount it.
Next is a Turtle Racing Complete Clutch system, It was originally orange but I de-anodized it and polished it, It could use a polish now though. Only minor thing is the right hole on the gear plate is a bit chewed up from a screw stripping out on me, Everything else like the bearings are perfectly fine, This never saw to much run time, Pinion is also in great condition.
I also have a set of rear tarmac busters mounted on stock HPI rims with red Beadlocks all aound, Tires have probably 50% life left.
Also a set of rear paddles mounted onto Pro line desperado wheels with Grey HPI Outer beadlocks with Pro line black inners. Great condition.
  Send a message via AIM to Wild YFZ 450
04.20.2011, 05:53 PM
r/c tech link please. ($)
Closed Thread
