MGM 12012-3s (Anyone Know How To Test)
DarcyRou
MGM 12012-3s (Anyone Know How To Test) - 10.24.2006, 11:00 AM
MGM Will Not Work 4s lipo
-15.12V Incoming
-Continuity Through (+) And each Motor Lead
-15.12V Through (-) and each motor lead
Light will not shut off (very dim)
when i turn the controller on it will beep the motor and flash bright, then go done to a dim steady on?????????????
Serum
Serum's Avatar
10.24.2006, 12:15 PM
I think you need to go thru the programming procedure.
DarcyRou
10.24.2006, 02:28 PM
I have quite a few times with same result, but at this point I'll try anything!!
Cartwheels
10.24.2006, 03:35 PM
You could try reversing the throttle servo on your Tx. It may or may not help.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
10.24.2006, 06:01 PM
Seems like it's been forever since I ran my MGM... don't even recall how to program it. But I think I recall that it's sensitive to the throttle neutral point when trying to program it. Keep playing with the radio settings if it's not going into program mode.
DarcyRou
10.24.2006, 06:13 PM
the esc was working fine for about two weeks then nothing!!
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
10.25.2006, 04:39 PM
contact Mike and see if he has any suggestions for you...
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
DarcyRou
10.28.2006, 06:43 PM
Just tried another test. Used an Mtroniks Truck ESC with everything else staying the same. The motor did run but was very eractic on acceleration and never went to full speed it had times for brief fractions of a second that the speed was like my mgm when I first got It . Is it my motor????? How Can I Tell???
DarcyRou
10.28.2006, 08:07 PM
Anyone want to purchase my MGM 12012-3s ????????
