New Project Help
Mark Fradkin
Rad Frad
New Project Help - 12.17.2006, 12:44 AM
9920 BEC JUMPER REMOVED
APACHEE 5S LIPO/ WONDERER 8XL
EXTERNAL BEC
HAVE KYOSHO INFERNO GT 2speed - MINUS NITRO STUFF
I want to use the mechanical brakes.
When wiring it up , do I program the 9920 foreward only, plug in the bec into battery slot ,steering servo into channel 1 ,existing thorottle/brake servo into channel 2 and leave channel 3 empty,? DOES this give thorottle to the wonderor and opposite braking power? This car has no reverse.
I like my nitro cars but hooked on brushless
bdebde
That's All Folks!
bdebde's Avatar
12.17.2006, 01:00 AM
you will need a y harness on the throttle channel. Plug in esc and brake servo there. Program esc forward only and dissable brakes.
coolhandcountry
coolhandcountry's Avatar
12.17.2006, 08:21 AM
Some times the servos don't work in the right direction. I have had this
problem with a few.
GorillaMaxx360
GorillaMaxx360's Avatar
12.17.2006, 10:57 AM
Welcome to the forums bdebde :)
Serum
Serum's Avatar
12.17.2006, 03:19 PM
Yes, the orientation of the servo's can be hard.. You need to think of something so you can use the servo you have in the right direction.
Programming the controller with the servo channel reversed won't work.. (at least, it didn't worked with my setups)
Mark Fradkin
Rad Frad
12.17.2006, 11:03 PM
So is it just a crap shoot on the servos or being in the right servo direction ahead of time> just dumb luck or all of that. It can be done ,right?. Do different servos behave differently. For running esc what servos in your opinion are best. As I set this up I perfer to do it right.
My quark125b brakes on pavement will just flip my Emaxx. 5s 9xl.
This progect is fof a Kyosho inferno GT- nitro stuff
Thanks Mark
coolhandcountry
12.18.2006, 09:28 AM
Different servos have different directions for some reason.
I think hi tec and futuba are different. I am not possitive though.
Mark Fradkin
Rad Frad
12.18.2006, 12:41 PM
Is it true that the Quark 125b does not have a foreward only, no brakes, setting?
neweuser
neweuser's Avatar
12.18.2006, 01:12 PM
there is a thread around here with the manual in a post, not sure where it is though.
