01.16.2007, 04:55 PM
Originally Posted by Serum
No, i think the set is the three taps.
You are correct. I changed my order. Just getting the one plug tap. If I need more taps, I can go to a local place here. This way, I can see what is being purchased!
Hot n Cold - Yes sir, have the lube already with the handles for the tap. Can someone advise on the set degree? PLEASE!
Thanks Guys!
I wish I could find my whole tap set that I got when I jacked the threads on a water pump....cannot find it now though! ARG! It was like a 30 piece set!
01.16.2007, 05:25 PM
LOL! yeah Walter! i've got a nice experiment of your revo centerdiffholder laying here.. I think it has got 2 taps and 4 drills in it.. :p
01.16.2007, 06:03 PM
So, any advice on the degree of a set for a screw? I cannot seem to find it anywhere!
That's All Folks!
01.17.2007, 02:31 AM
Look for countersink bit, is that what you're looking for?
01.17.2007, 07:10 AM
Yeah, is that it Newe?
01.17.2007, 10:13 AM
YEAH! That is it! I kept looking for "screw setter"! Yeah, I'm a DA! Anyways, I will search this, is there a specific degree though? For some reason I thought there was?
01.17.2007, 02:00 PM
90 degrees IIRC
01.17.2007, 02:08 PM
90 degrees IIRC
Thanks Serum! What is IIRC? Sorry for all the dumb questions!:005:
That's All Folks!
01.17.2007, 02:23 PM
I think 82 degrees is most common angle.
01.17.2007, 02:28 PM
Well, with M3 screws, to set them in, I know they are a specific setting degree from my understanding. Just need to be sure on that. I think Serum might be right, as he usually is.
Ok, so they have 82* and 90*. Also, what does the "shank" mean?
That's All Folks!
01.17.2007, 04:05 PM
Shank size, is where it goes in the drill on a single ended one, it is the outside diameter on the double ended ones. Get one that has an outside diameter of your screws head, or just slightly larger. I do believe that 82 degrees is standard for most screws.
That's All Folks!
01.17.2007, 04:11 PM
All the ones I have here at work are 82 degrees (at work now). I will have to check the one at home to be sure (it is the one that I actually use for 3mm screws on rc cars).
01.17.2007, 04:26 PM
thanks man! wouldn't happen to have one for sale would you? LOL
01.17.2007, 06:14 PM
It could be 82 degrees, with my 90 degree only the shoulder of the screw hits the material.
IIRC; If I Recall Correctly.. Didn't knew it either, here is a good searchengines for oldies like us; www.urbandictionary.com
01.17.2007, 06:22 PM
Hey Serum. Thank you for all your help. I got an 82* and will see how it pans out.
If you guys are wondering why all of these DA questions, I plan on trying....and I mean trying to customize a chassis for my rc18t. The only tricky part that i can see is how the nose is at a slight angle. Now, carbon fiber does not bend, so need to figure that part out. maybe the front of the chassis will have to be part aluminum.
