rchippie
rchippie's Avatar
01.20.2007, 10:09 PM
Originally Posted by BrianG
Yeah, I hope it's the BEC too. Good luck, and let us know what it turned out to be.
I went to the track today with the UBEC removed & a reciver pack installed. It still lost the signal after about 5-6 minutes of running.
REAL MEN RUN BRUSHLESS
Bomb-Proof
01.20.2007, 10:12 PM
A ubec can just drop out, it's not said it's stuttering, it's just stopping. A ubec with a thermal problem or such, might just loose it's power. Not necessarily causing a stuttering/cogging problem.
if it shuts down it will cause a shuttering problem, indicating it has shut down.
Got the red wire unplugged going to the Rx??
coolhandcountry
coolhandcountry's Avatar
01.20.2007, 10:14 PM
Did you loose steering to when it happened with the rx pack?
If so I say rx is faulting.
rchippie
rchippie's Avatar
01.20.2007, 10:23 PM
No stuttering just looses signale for a couple of seconds then kicks back in. Temps were around 140 on the side of the MM heat sink , & i still had steering. Yes i have the red wire unplugged.
coolhandcountry
01.20.2007, 10:37 PM
Ok. Have you tried to change the gearing a little?
I may be thermalling and the fan is cooling it off before you get a accuall reading of temp.
rchippie
rchippie's Avatar
01.20.2007, 10:40 PM
Leroy i've thought that maybe the issue but i dont have anymore gears . Can i call you ?.
coolhandcountry
01.20.2007, 10:55 PM
You got pm.
Bomb-Proof
01.21.2007, 01:38 AM
I dont think its esc related.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.21.2007, 01:48 AM
I think there may be something wrong with the esc... I have one that does something similar. It's going back to CC but I haven't sent it yet.
Mine will start doing it after a few minutes... and once it does, it happens over and over. It "reboots"... shuts off and back on. It does a beeping/flashing thing like when it's first turned on... I'm not sure if it's exactly like the same or not. I guess I should have paid closer attention.
I played with it the other day and it will even reboot with just a slight throttle input if there's a high load on the motor, like a foot in front of the car. :)
It can't be a failsafe kicking in... like low voltage, over current, thermal... all vital signs are good. Well, it could be a failsafe, but it's malfunctioning.
It's not supposed to do this and it's never done it before.
Edit: Oh, and I have tried 3 ubecs, 2 batteries, 2 rx's, 2 servos... no luck. Only thing not changed out was the motor and esc.
Serum
Serum's Avatar
01.21.2007, 04:49 AM
incorrect; if the UBEC would shutdown, you would not neccesarely have a stutter, as simple as that.
Weird thing now the UBEC is replaced with an external pack, that you keep the steering. while the esc shuts down;
Mike, here are a few q's;
-Did you tried another set of batteries? and what batteries is it that you are using?
-Is your LVC disabled?
-have you got another receiver to try?
-did you tried reprogramming the esc?
coolhandcountry
01.21.2007, 09:42 AM
I talked to hippie on phone. The buggy he used to run was geared lower than
the buggy with problem. Higher gearing more amp draw more heat. Yes the
fan helps cool the esc but it is still cooling while you are trying to get temp gun
and a temp reading. He can't drop the gearing for way the buggy is set up.
Well he can but it is not easy or cheap. How else could one tell if it is a
thermal problem if you can't change gearing?
01.21.2007, 10:13 AM
Maybe use some smaller tires somehow?? I would also decrease the start power as much as possible. That should also be a little more gentle on the ESC...
rchippie
rchippie's Avatar
01.21.2007, 12:30 PM
Rene in answer to your ?
Yes 3800's
Yes
Yes i will try a different reciver latter.
No
GorillaMaxx360
GorillaMaxx360's Avatar
01.21.2007, 02:16 PM
mabey try reprogramming the esc because that is the only thing on the list you did not try.
Serum
Serum's Avatar
01.21.2007, 04:27 PM
@ rchippie; 3800's of what brand?
Please let me know what the other receiver does.
