jollyjumper
RC-Monster jumper
jollyjumper's Avatar
03.08.2007, 07:04 AM
sweet, thanks again guys.
losi 8ight-t
xray xt8
AAngel
03.16.2007, 02:42 AM
I just did a Muggy conversion yesterday. It took me a few hours to do. It was really simple. What made me go with the Muggy was the fact that it had a conventional 1/8 scale layout, with the center diff.
I used the optional aluminum center diff mount to mount the motor mount to. It's a very rigid setup and very straight forward. If you do go with the Muggy, this first thing I had to do was get rid of the dual steering servo setup. I went with a JR Z9000T. The next thing I did was to replace the bushing in the steering with bearings. Then I replaced the grease in the diffs with diff fluid and changed the shock oil to 40 weight.
I like it, so far. It handles very well for such a heavy vehicle. In fact, it handle better than my buggy does. I think the buggy's gonna be on the shelf for a while.
jollyjumper
RC-Monster jumper
Talking 03.16.2007, 04:28 AM
you will have to post pics now lol.
i actually found a roller with a heap of spare's locally, i'll get that one.
losi 8ight-t
xray xt8
AAngel
03.16.2007, 04:33 AM
jolly,
My pic host account came due, and I don't know if I'll renew it. If you want, you could PM me with your email and I'll send you some. I may even still have the first mount that I did, to give you an idea, although I may have cut that one for the plastic diff mount. Believe it or not, the aluminum diff mounts are a bit longer (taller) and the mount made for the plastick diff mount doesn't quite fit the aluminum mount.
MetalMan
MetalMan's Avatar
03.16.2007, 04:01 PM
How about Photobucket for hosting your pics?
AAngel
03.16.2007, 04:19 PM
What? Is photobucket free? If it is, I didn't know that. I'll check it out.
Gustav
Gustav's Avatar
03.16.2007, 04:38 PM
Yup,photobucket is free.You can just attach files to your post on this forum anyway.
MetalMan
MetalMan's Avatar
http://www.photobucket.com
That's where all of my pics are hosted (for free) :).
AAngel
03.17.2007, 05:31 AM
MetalMan, thanks for the photobucket tip.
OK,...here are some pics. Keep in mind that I just got the truck two days ago, so it might be a little rough and things are likely to change, but this is how I'm running it right now.
I tried to get shots from the most pertinent angles. If you need anything else, let me know.
jollyjumper
RC-Monster jumper
03.17.2007, 06:14 AM
looks like a steel spur. does it hold up?
wich battery you running? i assume 4s lipo?
thanks.
losi 8ight-t
xray xt8
AAngel
03.17.2007, 12:46 PM
jollyjumper,
That is a metal spur in there right now and the spur doesn't last long. You could go with the hardened steel pinions, but from what I hear, they don't last long either. I usually run a Kyosho plastic spur, but a rock fried my last one yesterday.
I'm running 4S Lipo. I have a couple of Kokam 4800mAh packs on the way, because the truck handles better with the light batteries. I usually run a 4S2P 8000mAh pack for runtime in the 30 minute range.
jollyjumper
RC-Monster jumper
03.17.2007, 05:10 PM
how much Kv is the motor? and how are you geared?
thank you.
losi 8ight-t
xray xt8
AAngel
03.18.2007, 08:21 PM
I have to correct what I said above. The pinion does't last long when used with a steel spur gear.
The motor is a 7XL. It's about a 2150kv motor. My gearing with the stock tires is 12/46. On 14/46 it was just too stupid on the track.
I did run it on the track yesterday, and I made a few observations. The first is that the steering sucks. I replaced the ackerman arm (the thingy that connects the right to the left) with a tie rod ball end setup and it tightened things up a bit, but it's still not great. The second is that I was having a problem eating spurs. I went through four last night. The problem is one of two things. It is either a lack of rock guards and things are flying up into the gears or the chassis flex is somehow causing the gears to mash. I don't know how the chassis flex could be affecting it because my motor mount is mounted to the center diff mount, but I'm not ruling it out. I'm going to install some rock guards and see what happens. The thing is that I haven't actually found anything stuck in the gears. Just to play it safe, I ordered the heavy duty chassis.
The last thing I noticed is that the stock tires suck too. They are fine for bashing, but leave a lot to be desired on the track. I have some holeshots and bow ties coming in and will convert to 17mm hexes.
On the positive side, I think that the truggy will wind up handling better than a buggy. It takes turns at higher speeds and is more forgiving when you don't hit the turns or jumps quite right.
03.18.2007, 08:35 PM
Yeah, a "normal" pinion won't last long at all on a steel spur. For one thing, the teeth are shaped different. For another, mesh has to be rock solid. At the minimum, I'd use a hardened steel pinion as the teeth are shaped right and are meant to use with steel spurs (most usually are modded clutchbells).
You can read this thread about this topic.
gizzmo79
03.19.2007, 05:24 PM
Nice truck
What did you use for motor mount? On this truggy is it mod1 pitch?
Sorry the bad english i'm from Norway
